Old 07-07-2011, 11:52 PM
STiLtd683's Avatar
STiLtd683 STiLtd683 is offline
Pulled the engine. Again.
'94 SVX
'92 SVX
Old 07-10-2011, 12:59 PM
Huskymaniac's Avatar
Uses the ignore feature
Applied Leatherique and am letting it bake in until later today. I might put some Zymol on the rubber seals later too.
Tony
Old 07-10-2011, 01:58 PM
bwb3's Avatar
bwb3 bwb3 is offline
Cruisin' in Gator Country
Valve cover gaskets, cam seals, timing belt, water pump, 4 pulleys, power steering pump O' ring and seals, spark plugs and rear Koni's. No more leaks and, damn, I might be in shape for 20/13.
Gene Sat back with a beer (s). Thanks Ben (my son) and Dave (at R&N Foreign Auto).
Gene and Ben
Old 07-10-2011, 08:03 PM
kinz kinz is offline
Washed and changed over to stock rims with old rubber for storage. Stuck her in the garage and unhooked battery. Just about ready to hibernate for a while.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 07-10-2011, 08:34 PM
SVX_MY_BABY's Avatar
Storage in the summer?
Peter
Old 07-10-2011, 08:41 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
I collected up the items that are going with the Pearly in the sale. Shined up the headlights for kicks.
Old 07-12-2011, 03:00 PM
Oil/filter change, greased the Nev sway bar bushings, and plugged some screw holes in my raggedy old tires.
Old 07-12-2011, 04:27 PM
For deployment, so not just the summer.
Old 07-12-2011, 05:06 PM
dbarnblatt's Avatar
cam seals
timing belt
new idler, pulleys, and tensioner
timing belt cover gaskets
oil seals
water pump
thermostat
power steering pump
spark plugs
alternator belt
AC belt
change trans fluid
oil change
coolant flush
powder coated power steering pump bracket
powder coated AC bracket
powder coated upper radiator supports
whew... Ivo at Renner Motorsports in LA did the work. Great guys, great shop!
Old 07-12-2011, 07:25 PM
I waxed mine detailed the motor and repainted the stock winter rims
You need a little more blue. Finish it off with one of these
I like the threaded posts for attaching additional power and ground wires.
Old 07-12-2011, 07:38 PM
LetItSnow's Avatar
Watched my Pearly leave my driveway for the last time.
Old 07-12-2011, 07:46 PM
radarwhiz's Avatar
Fairmont State University
Hope it was in the hands of a new owner!
Elazar
'08 ML550 daily driver
'13 F150 work truck
'87 MR2 racecar
'92 Lsl Claret 5sp
Old 07-12-2011, 07:49 PM
Obewon Obewon is offline
After being away from home in Toronto for a week ... started it up, let it settle to a silky-smooth idle, and got out to walk around and admire it
92 SVX, Ebony Mica 186,000 kms
92 Mercedes Benz 300CE, Arctic White 187,000 kms
Old 07-12-2011, 08:37 PM
michael's Avatar
michael michael is offline
What Potholes ???
Blue battery cool
Blue flex loom not so much
to each his own
Rad hose is nice too
Wanted: Steering Wheel
Old 07-12-2011, 09:01 PM
LetItSnow's Avatar
Well, on a trailer rented by a new owner!
