Old 06-21-2015, 09:54 PM
simboglide's Avatar
simboglide simboglide is offline
Re: need svx Radiator...
But Sillas are a single pass radiator.
Old 06-22-2015, 04:27 AM
Must have been the wrong single pass then.
2 cars, 2 Sillas, no problems.(except there are none available) So I guess the answer is yes, if it's the correct single pass for the car.
Old 06-22-2015, 06:31 AM
simboglide's Avatar
Think ill' buy the two they show to have left.
Old 06-22-2015, 06:27 PM
simboglide's Avatar
Heh...go figure...they didn't have them after all.
Old 06-22-2015, 06:45 PM
We really need to figure out what cars have a compatible radiator. There must be other cars with a similar radiator design.
Old 06-22-2015, 07:00 PM
gwynethh's Avatar
gwynethh gwynethh is offline
Silla again says "Available Soon". This time when it shows up on Amazon we will grab one IMMEDIATELY.
"Peace is the flower of justice."
Old 06-22-2015, 07:02 PM
Silla has been saying "available soon" for about 3 years for their SVX condensers, Don't hold your breath.
Old 06-22-2015, 10:29 PM
simboglide's Avatar
Closest I have found is a 2000-2004 Legacy...the top and bottom mounting pins are in different locations and you'd likely need to use the top Legacy hose to reach the water neck on the engine...sooooo..that bringy said... Drill holes in the rad. Support to relocate the mounting brackets.. Or cut and epoxy the pins for relocation and hope they hold.
Old 06-22-2015, 10:35 PM
I actually have a better solution.
However it requires fabrication, different hoses, different fans, a rewireing of said fans.
I have done it many times.
So, who is in?
Old 06-23-2015, 06:22 AM
simboglide's Avatar
Hell
...I'm game...fire away.
Old 06-23-2015, 07:15 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
So, who is in?
I'm in. As I've mentioned before, I want to upgrade to a crossflow-style radiator.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 06-23-2015, 08:17 AM
spacepig spacepig is offline
http://www.rywire.com/product-p/radiator-custom.htm
Bit more expensive but this might be a good option. Anyone have experience with something like this? I know Rywire is respected in the riced engine bay/legitimate motorsport community for their military spec wiring harness but I've got no idea about their radiator. Seems legit in any case.
Old 06-23-2015, 02:02 PM
simboglide's Avatar
Nice set up..but since I'm totally stock..I'd go OEM and add a tranny cooler...no fuss..no muss.
Old 06-28-2015, 08:56 PM
simboglide's Avatar
Dayle Gray at Planet-SVX "assures" me he will have a few in August.
