Old 06-01-2012, 03:45 PM
dromano's Avatar
dromano dromano is offline
Re: Want to do a tuneup. Suggestions?
Since its most likely warm where you are
you could pressure wash the engine at a car wash.
This will usually show up a failing coil.
However make sure that you stay away from the coils on a wet, running engine,
BECAUSE A 50,000 VOLT COIL/STUNGUN CAN KILL YOU,
if powered by a big 12 volt system with a giant battery, helped along by a 90 amp alternator!
And, last month I installed a new yellow top Optima Intersate monster 12 volt, at least it's dry in the desert.
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited
2012 Outback 3.6R Limited!
Old 06-01-2012, 05:20 PM
Originally Posted by dromano View Post
And, last month I intalled a new yellow top Optima Intersate monster 12 volt, at least it's dry in the desert.
But not outside the car wash.
Old 06-01-2012, 06:25 PM
dromano's Avatar
I don't go there, too expensive! The basic no extras car wash is $9.95
Old 06-01-2012, 06:35 PM
There is a place here in Cumberland Maryland, owned true Hot Rodder, who has a bunch of DIY bays that give you 4 minutes for $1.00.
$0.25 extra for each additional minute.
Old 06-01-2012, 07:31 PM
dromano's Avatar
We have those here. Don't go there either, it's where the gang bangers hang. Too many Mexican malo hombres, not enough self service car wash places I would pack my 45 semi auto but, I would be arrested for illegal pistol carry in the wonderland of Mexifornia Utah, here I come AKA, damned if you do, damned if you don't. Mostly I just stay home guarding the fort.
Old 06-01-2012, 07:59 PM
Maryland is right now, as bad as California in terms of carry, but I live in WEST BY GOD VIRGINIA!
2.6 miles from Maryland.
Its a different world from DC.
Keep your powder dry.
Old 06-01-2012, 08:32 PM
dromano's Avatar
Good on ya Tom, when I leave Mexifornia for Montana as soon as I cross into Nevada the 45 semi auto moves from the trunk to the shot gun seat! all the way through Utah, Wyoming & into Montana. Open carry is what it is once out of Moonbeam Jerry Brown's tax & bleed those left to pay that haven't moved to Texas.
I was born in California & it has turned into a sh*t hole, nuff said.
Old 06-03-2012, 05:51 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Ok, just got to test drive after getting everything back together.
Here's some of what I found when working on it:
One of the rubber intake boots wasn't properly seated last time it was installed. This may have caused some of my problems since it could have been taking in unmetered air where the rubber was folded over.
Someone wrote "SVX" on my MAF! Probably not the original...
I also found this scratched in the mating face of the MAF:
My camshaft is named Rex
Those valve covers were dirty!
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-03-2012, 05:59 PM
dromano's Avatar
Ugly job, someone has to do it, I did. Removing & replacing the valve covers was a MOST miserable task Had to invent tools to work the tightest spots, never again, I hope. It was great to look at perfectly cleaned valve covers
Old 06-03-2012, 06:07 PM
SVX8588's Avatar
Here's why I was having so much oil leaking everywhere:
Hopefully my dipstick won't pop up anymore!
I also have two number "3" injectors!
Anyway, it seems to run a bit better. I'll have to wait for a chilly morning to know for sure if the hesitation is completely gone. It seemed a little bit snappier when starting from a stop. At one point, before it was warmed up, I came to a stop and it wasn't idling smoothly and almost died at one point. Dunno what that's about. I probably ought to put some Techron in it now.
There's still some smoke coming out when I stop the car, but I think that's just residual oil burning off. I inspected the seals carefully and there were two spots where they seemed slightly damp, but I think it's from oil that was on the motor.
I'm going to run it for a day or two and then change the oil and filter.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-03-2012, 06:12 PM
SVX8588's Avatar
I didn't think it was too bad. I borrowed my brother's Gear Ratchet set. That made it a lot easier. I also took a lot of time cleaning everything and I painted a few rusty spots under the hood while I had the battery and airbox out, so that's why it took me so long. It's nice to have another vehicle to drive when working on it
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-03-2012, 06:47 PM
1)A folded snorkus is ALOT more common than you would think.
2)The MAF has the correct #22680 AA200 A36-601 R62
3)Its not unusual to have a mix of fuel injector COVERS.
4)Eww!
Old 06-03-2012, 06:51 PM
dromano's Avatar
Originally Posted by 92snowmachine View Post
not to post to disagree but i wouldn't put anti-sieze on the plugs. if torqued properly they should be no problem to remove next time.
The issue with "torqued properly" is the limited space to even think about a torque wrench in such a teeny space. I'm thinking you have not changed plugs on this engine The available space is a primo bit*h.
SVX8588, if you decide to pull the engine be certain to do both the front oil pump seal & the rear crank seal, I did all the front seals, the rear crank seal is worth about a quart of oil per 1k miles, which I didn't change.
Old 06-03-2012, 06:52 PM
SVX8588's Avatar
Would it make any noticeable difference in how the car runs?
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 06-03-2012, 06:57 PM
SVX8588's Avatar
I didn't pull the engine. I was able to do the valve cover seals and plugs just fine without pulling it. But that's good to know if I ever do
The box that my plugs came in said to thread the plug in until the washer touches and then go another 1/2 to 2/3 turn after that. I did put anti-seize on them anyway. When I tightened the bolts for the valve covers, I was able to use a torque wrench on all but 2 on each size. Those I just did by feel.
Glen
2002 F550 74K
1987 BMW 535i 209K
1999 Yamaha SRX 700
