Old 01-11-2011, 02:29 AM
Re: wideband emplacement
Originally Posted by Nevin View Post
As long as there are no leaks in your exhaust, you can put it anywhere. There are plenty of tuners that clip a mobile wideband right onto the exhaust tip when they're doing tuning.
At idle it goes from 14.4 or so to 15ish. Usually in that region. Then while cruising about the same. WOT usually goes to about 12.5.
Unless you are under boost, THEN 11.5 or so is conservative.
Nevin, writing a check now.
Old 01-11-2011, 11:16 AM
Nevin's Avatar
Nevin Nevin is offline
Honestly, now that I read what I wrote, I don't even know if that's what it usually is. I just know that it runs just fine. I just wanted to get before/after AFR's to compare for when I go turbo. THe wideband will probably come out again sometime soon, and hopefully go in the WRX wagon i'm buying.
No worries, I'm keeping the svx.
Tom, I'll keep my eye on the mail.
Jesus is the remedy
2015 Expedition EL Ecoboost
