Old 03-13-2010, 06:45 PM
NeedForSpeed NeedForSpeed is offline
Re: My Pearly... Now with M04r w1n
You did this three years ago and did not tell me......
Bi+ch!
Well, it wasn't as easy as I thought it would be
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 03-13-2010, 06:49 PM
Bi+ch!
I've been a bit distracted the past couple years, relocating and other life-stuff ,
I'll be caught up this summer, so, you will hear more from me here
Old 03-14-2010, 08:47 AM
It was a yellow wire sol. C. I did get to installing the switch yesterday which has opened the diff by not sending any pulsewidth to the solenoid. Yes it throws a code... but at least it is not binding anymore.
Old 03-14-2010, 11:06 AM
That should do it
I will be most interested to hear about your driving impressions
What final gear are you running?
Old 03-14-2010, 12:58 PM
Originally Posted by NeedForSpeed View Post
That should do it
Running stock 3.545 gears for gas mileage and quite frankly, im not interested in fixing what aint broke... Not to mention, warranty on the trans
Old 03-14-2010, 06:04 PM
Nevin's Avatar
Nevin Nevin is offline
Next up on the VTD list... me. Waiting to get that uber secret TCU of awesomeness.
Tom, couldn't you just pull the front shafts too, leave the nubs in and run it RWD.
p.s. I can't wait to be VTD!! Mine's a 4.11, so I kinda sorta have high hopes. I got my trans cooler/fan/thermostat this week and LAN shipped my built VB. Should be a heck of a drive!
Jesus is the remedy
2015 Expedition EL Ecoboost
Old 03-14-2010, 07:18 PM
Pulling the shafts you lose your ability to park with the parking prawl... I am not looking to keep it RWD either. I am also awaiting the correct TCU for it to function properly... In which case the RWD switch will be removed
Old 03-14-2010, 08:25 PM
92 SVX 92 SVX is offline
It is not truely RWD right now is it? I thought they were 35/65 or something.
Old 03-14-2010, 10:30 PM
Nevin's Avatar
Those are the numbers I have heard as well. I think I've read 36/64 before as well. Somewhere in that region anyhow.
Jesus is the remedy
Old 03-15-2010, 06:17 PM
yes that is about right... The fact of the matter is, it is an open mechanical diff... Without severe delta from the front/rear the rear will see mostly all of it though
Old 03-15-2010, 09:10 PM
I would love to have that on my car. I prefer the RWD handling characteristics.
Old 03-24-2012, 07:44 PM
michael's Avatar
michael michael is offline
What Potholes ???
Was this issue ever resolved, if so how? Is a TCU swap a solution or maybe a reflash? I know Toms not around much anymore. Any help is appreciated, all options welcome.
Wanted: Steering Wheel
Old 03-24-2012, 07:53 PM
What issue exactly?
A few JDM VTD transmissions have been installed. You just need to have a matching TCU to the C solenoid as they reversed the signal sometime in the production run. I believe in 94 or 95.
Old 03-24-2012, 08:09 PM
michael's Avatar
What Potholes ???
It might be best if you read the whole thread. Slight binding, Need for some switch, TCU Codes for C solenoid.
Old 03-25-2012, 07:01 AM
michael's Avatar
What Potholes ???
I hope I didn't come across as being sarcastic. I don't know that much about the VTD. I'm posting this for a friend, he bought Tom's SVX a while ago, and would like to get the codes cleared up. Nate you said the VTD is JDM, Only? Sounds to me the best solution would be a JDM TCU. Would that mean a JDM ECU would also be necessary? What did you do with your swaps to get it functioning properly?
