Re: My Pearly... Now with M04r w1n
Well, it wasn't as easy as I thought it would be
I've been a bit distracted the past couple years, relocating and other life-stuff ,
I'll be caught up this summer, so, you will hear more from me here
It was a yellow wire sol. C. I did get to installing the switch yesterday which has opened the diff by not sending any pulsewidth to the solenoid. Yes it throws a code... but at least it is not binding anymore.
Tom |
I will be most interested to hear about your driving impressions What final gear are you running?
Tom |
Next up on the VTD list... me. Waiting to get that uber secret TCU of awesomeness.
Tom, couldn't you just pull the front shafts too, leave the nubs in and run it RWD. p.s. I can't wait to be VTD!! Mine's a 4.11, so I kinda sorta have high hopes. I got my trans cooler/fan/thermostat this week and LAN shipped my built VB. Should be a heck of a drive!
Jesus is the remedy 2015 Expedition EL Ecoboost Ebony Pearl '95 Subaru SVX LSi Home of the Bontrager Works 22mm rear sway bar!! |
Tom |
It is not truely RWD right now is it? I thought they were 35/65 or something.
Those are the numbers I have heard as well. I think I've read 36/64 before as well. Somewhere in that region anyhow.
yes that is about right... The fact of the matter is, it is an open mechanical diff... Without severe delta from the front/rear the rear will see mostly all of it though
Tom |
I would love to have that on my car. I prefer the RWD handling characteristics.
Was this issue ever resolved, if so how? Is a TCU swap a solution or maybe a reflash? I know Toms not around much anymore. Any help is appreciated, all options welcome.
#28
A few JDM VTD transmissions have been installed. You just need to have a matching TCU to the C solenoid as they reversed the signal sometime in the production run. I believe in 94 or 95. |
#29
It might be best if you read the whole thread. Slight binding, Need for some switch, TCU Codes for C solenoid.
#30
I hope I didn't come across as being sarcastic. I don't know that much about the VTD. I'm posting this for a friend, he bought Tom's SVX a while ago, and would like to get the codes cleared up. Nate you said the VTD is JDM, Only? Sounds to me the best solution would be a JDM TCU. Would that mean a JDM ECU would also be necessary? What did you do with your swaps to get it functioning properly?
