Re: New Alternator Wiring Upgrade Configuration
Oh man, Rocket man agrees with me yet again!
![]() ![]() Quote:
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
“I removed the two white wires and cut them back about two feet. One of these wires was factory-spliced into three wires close to the battery. I put new ring connectors on each of these wires and connected them straight to the battery.” The original arrangement protected these circuits as they were subsequent circuit wise, to the fusible link. You did not answer my e-mail query, as to whether your faulty wiring was in fact original. If not this could have lead you astray with the rewiring and the desired connection via the fuse box and fusible link. The heavy wiring you have correctly protected with a fuse and in respect of gauge should be OK. It is not at all likely that the heavy wiring could become overloaded to any dangerous extent due to the short length involved, possible voltage drop being the main concern. Forget the sales blurb regarding oxygen free copper, however fine stranding providing good flexibility is worthwhile, as are good connections and mechanical robustness. In this regard you are much commended.
Trevor, New Zealand. As a child, on cold mornings I gladly stood in cowpats to warm my bare feet, but I detest bull$hit! ![]() |
Hi !
I'm not clear on this...
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
must be something in the air
![]() ![]() -Bill
-Bill
So they only see 12.6volts or whatever the battery produces. ![]()
What HE said! ![]()
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
I REALLY like the way it came out!
1991 SVX L JDM |
My post infers that in deciding the gauge when replacing the heavy wiring, overloading should not be a likely concern and voltage drop would be the foremost issue to take into account. I did not say that YOU WOULD
get voltage drop, but only that this is the main concern to be taken into account; i.e. as you have done, as was pertinent in respect of the exercise. Interestingly, any conductor has resistance and involves voltage drop to a degree, even though in practice this may be considered insignificant. Hence the super conductor research.
John, my first question will be like OT used to like to ask
![]() Do you guys weigh the stock alternator compare to your high output alternator? How many extra lbs do you put on or save? You're like increasing 68% output compare to the stock alternator? Do you keep a log of your mileages? Does it drop down your gas mileage like 1~2 mpg? Could you feel if the engine has more load from the higher output alternator at different rpms? Your alternator is rated at 160A? But at idle, how many amps would it produce? Do you also have the info of how many amps does a stock SVX need of its entire electrical system?
-SSSVX 92 LS-L TEAL since Aug '01 92 LS-L YELLOW since Mar '05 |
#28
![]() The new alternator will weigh within grams of the old alternator. Evan with the heavier wiring there is not a pound of weight differance. I am sure that John knows his mileage. The mileage would not drop at all. ![]() You could not feel the differance. Just because there is a higher output alternator it does not mean there is more output. It only provides the ability of higher output, when needed.
#29
looks very nice.
Matt 15 OBW premium w/eyesight ![]() A picture of an SVX in the garage ![]() |
#30
Good morning, OT
![]() Ok, thank you. I somehow have the concept (maybe is wrong) that a higher output alternator will draw more power from the engine and so the gas mileage might drop a bit. But, if you don't use that much, maybe it won't cause any difference. ![]()
