Old 02-22-2009, 01:07 PM
LetItSnow's Avatar
My 10th Subaru is a WRX
Re: studs breaking off
Apologies to OT... Let me start over.
svxAl: Is it safe to assume that you're not using the stock lug nuts?
Old 02-22-2009, 09:32 PM
svxAL's Avatar
svxAL svxAL is offline
more windows then a minivan..
im not using stock lugs have tried 3 sets of different ones (stocks wont fit)
*1994 5 speed, Barcelona Red W/ Black ebony pearl top FWD*murrano wheels,lowered with motorsports springs drilled and slotted rotors 20% tint,swapped in leather seats,full exhaust cat delete,15 min mod, red F&R energy bushings
Old 02-23-2009, 04:27 AM
essveeexxee essveeexxee is offline
10 characters.
Old 02-23-2009, 08:21 AM
Are you sure you're using the correct 12mmx1.25mm thread pitch lug nuts, as 12x1.5 is more common, many places will try to give you the 1.5 ones, which will cause similar results....
Old 02-23-2009, 12:26 PM
kwren's Avatar
kwren kwren is offline
Originally Posted by essveeexxee View Post
Well then you know, kwren, if your shoes are too big, they are prone to sheer off when rounding them corners.
Do you make the sounds too? Hrrrrrrrrrrrrt, EEEEeeeeeeeyowwwwww, Hrrrrrrrrrrrrrt....EEEEeeeeeeeeowwwwwwwww.
Pretty much!
Keith
Old 02-23-2009, 05:18 PM
10 characters.
Old 02-23-2009, 05:57 PM
benebob's Avatar
benebob benebob is offline
Have a poncho I can borrow?
What Huck said. There is a place in England that sells competition studs which fit although they're about an inch longer.
I also wonder if the rims have a larger hole then the 12mm stud (i.e. a standard size) which is allowing the wheels to move back and forth causing your bolts to shear off.
Old 02-23-2009, 08:43 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
That sounds like a bad idea!
Actually, we use anti seize on our fleet of trucks to prevent the nuts from fusing to the studs. It does not loosen the nuts, it just prevents them from fusing, making it easier to remove. I have broken some studs in the past, but have never had a problem since using anti seize.
Old 02-23-2009, 10:39 PM
RoughSilver92 RoughSilver92 is offline
I have always thought anti-seize on the lug nuts was bad, also. Ever since I was in high school working at the dealership and one of the service writers that was actually doing oil changes and tire rotating and balancing (they were short handed at the time) had a car come back with major damage after one of the wheels came off when the customer was driving it. After asking the guy some questions they found out he was using anti-seize on the lug nuts. All the techs and the service manager were convinced it was the anti-seize. Who knows, though, maybe he just didn't tighten that one down.
Old 02-24-2009, 12:39 AM
kwren's Avatar
Probably makes a difference where you put the stuff... Like maybe confine it to just the treads?
Keith
Old 02-24-2009, 01:06 PM
http://www.youtube.com/watch?v=TpP9-PaAlSs
Old 02-24-2009, 01:34 PM
dannmarr's Avatar
I work for my SVX
Probably makes a difference where you put the stuff... Like maybe confine it to just the treads? Keith
www.engineersedge.com/wwwboard/posts/13070.html
Old 07-07-2009, 10:40 PM
BoxerFanatic's Avatar
How hard are wheel studs and lugs to:
A: get? do most autozone type places stock 12x1.25 studs, and compatible shank/washer style lug nuts?
B: install... is it as easy as pounding the broken lug back through the hub, and pulling the new one into the hub, by tightening an open nut against the brake disc, to pull the stud splines into the hub?
Does the brake disc need to come off for that process, or is it more involved than this?
"What you plan, and what actually happens ain't exactly ever been similar..."
1992 Claret SVX. Rescued from certain destruction, and still on the road, where it belongs. Waiting for a bit of a makeover, when I can afford it.
2005 Garnet Red Pearl Legacy GT Limited 5-speed. - The late great Subaru sport touring sedan.
1999 Classic Red Miata, Preferred equipment package 5-speed. Fun, fun, fun, in the Sun, sun, sun.
Old 07-08-2009, 05:19 AM
A. yes on the studs, no on the lug nuts
B. Yes
And yes the rotor needs to come off to get to them.
Hope this helps
Old 07-08-2009, 08:07 AM
Ok... then the next logical question is, where do I get another lug nut? Do I have to go all the way to the nearest Subaru dealer, and hope their parts counter is open?
mail order and wait for shipping?
I was hoping to have the parts today, by going to the auto parts store... But I guess waiting is waiting, if it is necessary.
