Old 03-08-2004, 03:21 PM
Seraph's Avatar
Seraph Seraph is offline
I abuse them one at a time
Originally posted by mranderson
also what are all of those switches for below the head unit in the instrument panel pdf. I have a gap there and am processing some ideas to fill it.
They control my external lights and such.
Lwin M. Maung (Member # 147)
Current SVX: NONE
Old 03-08-2004, 03:31 PM
mranderson mranderson is offline
The One
Send a message via AIM to mranderson
awesome
Old 03-08-2004, 04:35 PM
Re: lots of little questions
4. What would cause my steering to pull right sometimes and then other times pull left pretty hard?
thanks for the help
Mranderson this could be caused by the rear drive not working correctly. If as you say it pulls " pretty hard ", this the front wheels starting to loose traction. When this happends the transfer clutch should tighten up to move torque to the back wheels to prevent the front from spinning.
If the rear is not getting the drive, the front diff will suffer a lot of jaring that can lead to it breaking. Test it out on gravel or grass, get somebody outside to watch the front/back wheels, and do a hard take off. If all is well the front and rear should spin together. There should be no delay between them. If only the fronts spin, then the transfer clutch is defective. This can be fixed without pulling the transmission out, just the rear end.
If you do a search on transfer clutch, you should find all you need to know.
Old 03-08-2004, 05:36 PM
NapaBavarian's Avatar
Good morning!
Re: Re: lots of little questions
Because we are nuts.
I'm an almond...
.Karl.
Old 03-09-2004, 10:06 AM
Ground wire
All stock svx's have a ground wire at each tailpipe. You can never have too many ground wires.
Old 03-10-2004, 05:21 AM
dcarrb dcarrb is offline
Re: Ground wire
Properly called a "radio earth cord," I discovered yesterday.
dcb
