Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 11-03-2003, 10:46 AM
Chicane Chicane is offline
Anti-BS Vigilante
http://www.subaru-svx.net/forum/show...5&pagenumber=1
There was another thread I was involved in that sparked a 'heated' debate. Bottom line is that tire pressure affects rolling diameter.
- Rob
Old 11-03-2003, 03:22 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Rob,
Just a measured piece of info to add to this discussion - when I was running in the MB autocross this Sunday I started with 39 psi in the back tires and 44 in the front to minimize the chance of the sidewalls rolling. After 4 runs the front tires had heated up to 49.5 psi while the back tires were still at 39. I used a digital tire gage for all measurements. It would have been interesting to have measured the O.D. of the tires...
-Bill
p.s. Harry (newsvx) and Mike (Rufus) also drove in the same autocross. Both of them did great -- I continue to learn from watching and listening to both of them.
Retired NASA Rocket Scientist
Center Network Member #989
Old 11-03-2003, 03:42 PM
Mr. Pockets's Avatar
Moderator
Originally posted by SVXRide
Rob,
-Bill
See, in that case, you'd be less concerned about a small detail like tire rolling diameter. Autocrossing is already pretty abusive, so why sweat the small stuff?
You know, Bill, I'll be entering my first autocross in less than two weeks. I can't friggin' wait!
2005 RX-8 Grand Touring
2005 Outback
2002 Mercedes-Benz E320 wagon
END OF LINE
Old 11-03-2003, 03:44 PM
Andy's Avatar
Andy Andy is offline
Send a message via Skype™ to Andy
Re: Understeer reduction via tire size change
Originally posted by fasteract
Has anyone tried mounting 245/45's on the front only with 225/50's stock on the rear as an attempt to reduce understeer on their SVX ? The 2 sizes are dimensionally the same except for tread width and Paisan et. al. confirm 245's fit w/o rub.
Craig
Understeer?
What's that??
Andy
If I would be a young man again and had to decide how to make my living, I
would not try to become a scientist or scholar or teacher. I would rather
choose to be a plumber or a peddler in the hope to find that modest degree
of independence still available under present circumstances.
-- Albert Einstein, The Reporter, November 18 1954
Old 11-03-2003, 03:46 PM
Sonar's Avatar
Sonar Sonar is offline
Lightbulb
-Would it be possible to use bicycle-computers (speedos) to measure each wheel (only small magnetos attached to the rim)?
Old 11-03-2003, 03:59 PM
SVXRide's Avatar
Pockets,
Enjoy! Harry (newsvx) got me hooked on it. It will chew on your tires, so make sure they're in good shape. Actually had the car semi-drifting around the 270 cones - definitely a rush. Now, if I can only get my brain to listen to Harry's advice that "slower is faster"....
-Bill
Old 11-03-2003, 04:02 PM
Moderator
I don't know what you could hope to learn from these, unless you put two on the car - one on a front wheel and one on a rear. Cycling computers tend to want the circumference of a tire. So if you figured out what the circumference was supposed to be, then plugged that number into both, you could drive for a bit and see what kind of discrepancy there was between the measurments the computers recorded from the front and rear wheels.
Of course, if you take any turns, you're going to see different numbers between those readings, anyway.
I still think that the simplest way to test how tire pressure affects rolling diameter is to measure the distance between the center of the hub and the ground at different tire pressures.
As much as I'd like to attach some sort of laser-rangefinder to the center of my SVX's wheels and see if the number changed at different pressures, I lack such an instrument. So I'll be using something low-tech. Like a stick. This is unquestionably less precise, but without a doubt cheaper.
2005 Outback
END OF LINE
Old 11-03-2003, 04:20 PM
Sonar's Avatar
-I had all 4 corners in mind .. and a loooong straight....
Then you can set different pressures and measure in "your" way, after that drive 1 mile or so (straight) and check the "counters" on the displays!
Old 11-03-2003, 04:33 PM
Moderator
You would, indeed, need a long straight for that.
2005 Outback
END OF LINE
Old 11-03-2003, 05:02 PM
mbtoloczko's Avatar
sans SVX
Use white-out on the sidewalls. Its not high-tech, but it works, and its cheap. Put a mark at the bottom of all your tires on the sidewall, drive straight for 1/2 mile, and look at the difference in revolutions between the front and rear tires. If your tires all have the same amount of tread, and there is at least a few psi more in the fronts than the rears, there will be less than 1 revolution difference between the front and rear after 1/2 mile. Try it with a variety air pressures in the front and rear. Its kind of a fun experiment. I did it a while back when I got new tires. It took a 37.5 psi in the front and 30.5 psi in the rear before the front and rear had the same rolling circumference for my 225/45-17 tires. If you do these measurements and also determine the rolling circumference, then you can find out exactly how much of a difference in rolling circumference there is between the front and rear.
Mychailo
Visit my locker
Old 07-25-2004, 05:22 PM
grnSVX96's Avatar
grnSVX96 grnSVX96 is offline
ex SVX owner - still keen tho
Question rolling diameters
mbtoloczko [or anyone else who'd like to chime in..ta]
I read with interest your tyre experiment, in my case with my rim/tyre combination 265/35x9x18 rear and 235/40x8x18 front, according to tyre calc programs my front tyre has a larger diameter by 0.3inches to the rear tyre, but with weight over the front...which way will the air pressure gap likely go wider front to back or lesser.
I will do the experiment after my car comes off the hoist, but if I can estimate the air pressure gaps to start it will give me something to work with..[yours with same tyre/rim f to b was a 7 psi difference..but with my front tyre being slightly 'longer' but with the weight of the engine over it ...do you see the psi gap even wider or narrower..??]
Also how do you compensate for heat load.. perhaps getting it right for when the tyres are cold wont this change when say the front tyres have heat in them more than the rears..
Thanks
dave
Dave Down Under
Old 07-26-2004, 12:14 AM
mbtoloczko's Avatar
sans SVX
When I do the tire diameter calculations, I get that the dia of the rear is 0.1" less than the dia of the front. Since the tire diameters are a bit different, keep an eye on the difference in revolutions as you move the car forward. You might want to check every 1/4 or 1/8 of a mile.
Mychailo
Visit my locker
Old 07-26-2004, 12:44 PM
Sonar's Avatar
I wonder if it is possible to "tap" into the ABS signal sensors, maybe in the ABS control box, and build a simple frequency counter to monitor all 4 wheels
Maybe I'll check into that l8er
/Sonny
Internal name: "SuperSonic"
-92 ebony black with 170k KM
*** -Stress is when you wake up screaming & you realize you haven't fallen asleep yet. ***
Old 07-29-2004, 03:00 PM
I'm sure you could do that but I think chalk would be that much easier.
