Old 03-23-2015, 10:30 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Found true blue posing in her favorite spot for a (spring) photo shot.
https://www.dropbox.com/s/0l3iob0g6f..._5363.JPG?dl=0
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 03-24-2015, 07:17 AM
Very nice.
Old 04-11-2015, 01:45 AM
Got windows tinted, new remote system (that I immediately hate), and finally wired up my reverse lights to work when shifting into reverse as opposed to a toggle switch (remote install guy hacked up my wiring).
Right now I am trying to move my Supertones from within the engine bay to behind the waterfall.
This is also the first time I have ever removed my the waterfall.
Old 04-11-2015, 10:51 AM
Originally Posted by INVADR View Post
I need to figure out how to read the ABS codes.
Go to SVX INFORMATION WAREHOUSE
Look for the SVXIpedia link on the top of the page. Click.
Go to Checking Error Codes. Third from the top. Click.
How to Check ABS Trouble Codes is at the top of the list.
Or just go here for the printable version:
http://www.svx-iw.com/svxiw/article/...php?article=80
Old 04-11-2015, 05:11 PM
theflystyle's Avatar
Started reassembly of the intake manifold. Attached the painted fuel lines, throttle body and various other bits. Started attaching the viton vacuum hoses as well.
OT - Thanks for the IRIS o-ring. She fit beautifully
1994 SVX LSi
2008 Legacy 3.0R
Old 04-11-2015, 06:51 PM
So clean and pretty. Looking good flystyle.
Today on mine I exchanged my Autozone alternator which had a slightly damaged post and installed the replacement alternator. Also installed my new OEM #1 coil which fixed my misfire.
Old 04-19-2015, 06:19 PM
Picked up a little something for the Legacy... One of my stock calipers seized up and this wasn't significantly more expensive than a set of remans.
Old 04-20-2015, 10:39 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I got my car back with two new front axles. Next project is to fix the rear wiper motor, it keeps blowing the fuse.
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 04-21-2015, 10:45 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Had to replace a cracked cyl. 3 exhaust valve in the Forester which is why it was only holding 30lbs of compression.
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 04-27-2015, 11:30 AM
I love building custom parts for the SVX, but every now and then it's nice to be able to just bolt something on to the car. Brembos are fun!
Old 04-27-2015, 02:16 PM
Getting my Ceikas installed today.
Old 04-27-2015, 02:17 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Expensive little venture, I presume ? Is there a post that lists the parts needed and/or a How To?
Thanks
Old 04-27-2015, 09:46 PM
If you're talking to me, yes it is expensive because I am paying someone to do it.
I'm 'bout dead broke now.
Old 05-24-2015, 08:52 PM
Installed the painted cowl & wiper bits back onto the car
1994 SVX LSi
2008 Legacy 3.0R
Old 05-26-2015, 03:10 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Picked up a little JDM goodness for the ol' RallyRex.
Version8 VF37 twinscroll.
