#241
Bill...as to the timing, the issue is all about the valve events...nothing to do with the spark timing. Consequently, the Megasquirt can't do anything about it.
It's mechanical...and all about having the cams timed properly from the outset. M |
#242
I got the idea you had a 3" exhaust mandral bent Ex from the dyno plot. http://www.subaru-svx.net/forum/atta...9&d=1181993643
#243
Yeah I realised that...no problems.
M |
#244
Matt,
Okay, looks like we're all straight on what exhaust system you're running So, didn't you say somewhere along the way in this thread that you'd modified the cam gears to allow you to shift the static timing? -Bill
#245
Yep...sure have. So I've got the opportunity to adjust them...just not sure what to put them to.
Factory has inlet opening at 4* BTDC and exhaust opening at 55* BBDC. We timed the new cams to open approximately 2.5* BTDC. Retarding the cam timing pushes the power up the curve, with a resultant loss in bottom end. |
#246
Come on Tom, you're showing your gray hairs now! 3" exhausts work perfect on a 1.6l honda!
British vehicles are my last ditch attempt to keep the nasty Italian thoughts in my mind at bay. So far its working. |
#247
#248
Small update.
Pulled the engine out yesterday (down to 2 hours!!) ready to inspect the static cam timing. Will have an update on this for you in a week I'd say. After Rallybob's experience with exactly the same spec as me, I have renewed confidence that we were on the right track. Time will tell. Matt |
#249
Are you using exhaust gas temperature sensors? If your still getting a big dropoff in torque at top end and the cam timing seems good, they may give you a clue as to what else could be wrong.
Other guesses for debate: valve float, head gasket leak, overtaxed or sticking fuel injectors (air/fuel ratio gauge would help here, too). The size of your exhaust pipe and the location of your Y could also be messing with the resonance, but it shouldn't have that huge of an effect with the size you're running. |
#250
Thanks for the response.
Was not using an EGT, but did have a wideband lambda sensor in to do all of the tuning. Can't recall what AFR we picked, but it was safe, not wild. It *shouldn't* be valve float, injectors or head gasket leak, but it certainly could be. I'm checking the timing tomorrow night, so will find out more then. M |
#251
Interesting read here! I just went through all 17 pages, quite the buildup Matt, kudos to you! I love rallying in any form.
I do wonder if the lower-than-expected torque and the lower-than-expected peak power are caused by two non-complimentary facts. Retarded cam timing as you are well aware of, typically pushes the rpm band up higher. Yet the fact that you are retaining the standard exhaust manifolds and small-ish secondary tubes probably prevents the larger cams from being able to do what they do best, and that is to use the overlap to scavenge at higher rpms. I'm curious as to what sort of back pressure may be present? |
#252
Are these opening numbers you've mentioned above measured at .00 lash, or at .002", .020", or .050" tappet rise? I think that given the increased duration, but only 1.5° change in inlet opening, you may well have the cams 17.5° or so retarded! |
#253
Which cam specs are you chasing? We graphed the factory cams and the new ones which I can provide the details around?
Matt |
#254
The figures in the post above are from the factory manual...I assume they are 0.00" lift.
We worked mostly off the "0.50 lift points for replicability. Matt |
#255
Example: I recall the standard cams were *about* 196° @ .050" tappet rise. And I *think* you mentioned your new cams had 230° @ .050" duration on the inlet side, correct? Presuming the lobe separation angle remained the same, and the duration is now 34° (@ .050") more, then the new intake opening should occur at about 17° earlier than on the standard cams. Hope I'm making sense. |
