#241
Re: STeeL's built motor/turbo build
Just a thought, did you fiddle with the spark plug wires?
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#242
No. Fiddle?
#243
"Fiddle with" means "mess with".
From that video, there is something definitely very wrong. What kind of motor mounts are sitting under that motor? And what condition? I also found removing the injectors from the rails to be a major PITA. I wish I knew some trick to getting them out, but I don't...
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#244
Sounds like it's running out of gas. Can you get a fuel pressure tester and see what pressure you're getting on the line leaving the fuel filter? Also, did you check the fpr before you reinstalled it and did you hook it up to the vacuum port in the intake?
Bill
#245
I do not have a fuel pressure gauge, never tested it before. I'd have to borrow something to test it.
It's sitting on stock motor mounts. I can't tell you anything about the condition.. They aren't new but they don't appear to be leaking. I have a pair of brand new Group N mounts in the back seat, but they haven't been modified to work yet. I intened to drive the car to a shop to have it done when all this started happening last year. |
#246
Someone mentioned checking the oil is the level higher then normal, does it smell like fuel? |
#247
As best I can tell I'm actually losing oil. It was low when we checked it over the weekend. Lower than full, anyway.
#248
Stupid question, but are the fuel pressure and return lines on the correct way?
'92 SVX LS Pearl White - 6mt |
#249
![]() 1997 Ebony #308 113k "The Black Diva"SOLD ![]() 1992 Black over Liquid Silver 152k SOLD ![]() 1992 Ebony 251k 444 SOLD ![]() 1999 Silver SLK230 134k SOLD 1997 Green Outback 137k SOLD 2013 Honda Accord I4 SOLD 2015 Subaru Crosstrek 30k 2018 Tesla M3 30k |
#250
I think so at least. It worked well enough to drive around the block a hand full of times, to the gas station and back, to the mall for dinner and back home, etc. before this all started. The motor was out of the car for around a couple years though so it's always possible I don't remember where something went. I can take a picture of anything you'd like to check.
#251
It's a quick and easy enough thing to check out so sure.
#252
fuel lines look to be hooked to their correct places on the engine. The engines sounds seriously out of time... whether it be spark or just a mechanical issue. Might want to pop the timing covers off of the sides and just check that the cams line up with the timing marks
Tom |
#253
^^^^ what Tom said. Also, are you running a Hydra or the stock ECU? It's hard to tell from the prior posts in this thread. The MAF should be removed if you're running the Hydra. Are you sure the harness to the ECU or Hydra is fully seated?
Bill
#254
Stock ECU right now. I've switched to the Hydra once to see if that would change anything but no dice.
#255
Good luck tracking the gremlins down. Cheers, Bill
