Old 06-28-2014, 05:41 PM
Looks like a lot of work putting new seats. Keep info coming.
Old 07-06-2014, 07:11 PM
michael's Avatar
michael michael is offline
What Potholes ???
Sorry if I'm hogging up the whole thread but I'm on a roll! Full interior detailing/restoration
Seats Conditioned
New Trunk carpet.
Engine cleaned
Edit: iPhones take really bad photos in low light
Wanted: Steering Wheel
Old 07-15-2014, 12:05 AM
ShaneHobson ShaneHobson is offline
Sold my spare NZDM car.
This should free up space (and cash) for a couple more parts cars.
Old 07-16-2014, 01:23 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Shane - which part of the country is it off to?.
Old 07-17-2014, 06:53 AM
SVX_MY_BABY's Avatar
Replaced my door speakers.
Had the lower exterior door garnish/cladding which I removed re-installed by a body shop. I just couldn't get the lower corners to pull in, which is why I removed it in the first place. They ended up using panel bond. Had the other door and lower quarter panel garnishes done at the same time.
Checked out my rear speakers since I had the rear inside panels and seats out then re-installed the inside trim panels and seat. Cleaned and conditioned the leather rear seat.
Peter
Old 07-17-2014, 12:10 PM
INVADR's Avatar
INVADR INVADR is offline
Pew Pew!
5-Speed swap hath begun.
This past weekend's activities: Got the seats, console, exhaust, trans, driveshaft, and rear diff removed from the car. The 4EAT is a godawful FAT LARD. Definitely glad it's out, and done leaking all over my garage.
This week's activities: 5-speed cross-member blasted and painted, HD plasma cut the spacer plates for the Gp-N motor mounts, and cut a few extra pieces of 12ga stainless for the rear shifter bracket, firewall hole plug, rubber shifter thingie holder-downer, and got the '08 flywheel machined.
This coming weekend's activities: Remove steering column, pedals, shifter assembly, and computers. Flush 08 5-speed trans, change over rear diffy parts, re-seal all the things, cram SVX stub shafts into WRX trans, change out engine rear main seal, install Gp-N motor mouints, and hopefully install trans and diff. If the trans and diff go in, I'll test fit the '08 WRX driveshaft. The wheelbase is VERY similar to an SVX, but I'm not entirely sure of the center support location.
I'll post more updates...eventually.
Mark S.
1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed
Old 07-17-2014, 06:58 PM
Wow that is in real nice shape. After the swap it will great inside too. Never regret having a 5 speed. What tranny are you using ?
Old 07-18-2014, 07:59 PM
Junk yard run today. Picked up a few items but this was my best score, a dark wood grain vent piece to replace my faded to purple piece. As you can see the original one was pretty bad. Sometimes it is the little things that make your day.
Old 07-19-2014, 03:52 PM
Invisible avatar
Talking Re: What have you done to your SVX (or other Subaru) today?
Well, today I took the '92 beast in for its annual VA safety inspection. It passed. Seems I put 800 miles on it since last year's probing. Seems I've got a certified garage (carport) queen. Still semi-pristine at 160K. Amen.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 07-19-2014, 06:06 PM
I only put about 800 on The Claret last year.
But most likely 25k on The Pearlie!
100 on The F150,
1200 0n The Suburban,
2500-8000 on Christine....
sigh...
Old 07-19-2014, 07:45 PM
Invisible avatar
100 on The F150,
sigh...
I tend to use the Pacifica for long distance cruises, the Miata for top-down days on the curves, the old Caravan during deer-hitting season, & the SVX for washing, & waxing.
'01 Miata SE - 79K
Old 07-20-2014, 02:49 PM
Wonder how long this will last... Downside of living in a construction zone.
Old 07-21-2014, 05:35 AM
MrSefe MrSefe is offline
Tried painting my waterfall black. Didn't work. (Don't worry. It's only plastidip)
Old 07-21-2014, 06:21 AM
I think it looks good.
Old 07-21-2014, 07:02 AM
If that plug's done properly it should last the life of the tire. I've had 2 such repairs.
Peter
