Old 04-08-2014, 08:57 AM
NiftySVX NiftySVX is offline
Originally Posted by SVX_MY_BABY View Post
The SVX has a VTD as it's regular transmission doesn't it? 36/64 split.
Not in the US. US cars came with the trans that has just a clutch and is FWD mechanical drive and rear drive is manipulated somewhere between 0 and a theoretical max of 50%. It is vastly inferior to the double planetary VTD.
Be glad you have it. The car drives like a FWD car with the US style. Especially as the trans ages and the rear torque goes down
1994 L Blue 3.70 VTD
ASE Master Automobile
ASE Advanced Level Specialist
Old 04-12-2014, 04:01 PM
shotgunslade's Avatar
Washed it, waxed it with Meguiar's carnuba wax, buffed it with a lambs wool power buffer and put it on eBay.
See it under Race Cars (not street legal)/ Road Racing. Buy it.
Old 04-12-2014, 05:04 PM
92 SVX 92 SVX is offline
I wish I could your car is so very awesome.
Old 04-12-2014, 05:09 PM
Got the 6 speed in, been driving and checking it. so far had to adjust a couple things but over all very very impressed with it.
Old 04-12-2014, 08:26 PM
bishop bishop is offline
new rear struts in the gl, both the old ones were completely blown.
Old 04-13-2014, 06:03 AM
steamer99's Avatar
steamer99 steamer99 is offline
Repaired/upgraded the Alternator wires, hopefully no more intermittent christmas tree lights and stalling
current stable, subject to change without notice:
1995 Red SVX, 4.44 & Quick Change
2014 Nissan Titan S 4X4
1992 Teal SVX parts car
Old 04-14-2014, 12:47 PM
Saturday: Took a wire wheel to the parts that came out of my electrolysis bath, washed them, and then got the paint out. Before/after comparison:
Sunday: Dropped my fuel tank to I can tackle the totally ****ed up lines back there. That droopy thing is a brake line that some halfwit mangled into place (didn't even bother removing the old blown ones, the spots where they touched were causing the newer ones to corrode badly). The rust spots on the chassis are going to get cleaned up and painted with POR-15. Should be good after that.
Old 04-16-2014, 09:21 PM
Tapani Tapani is offline
I had overfilled the 5EAT in the Outback.... by a quart. Drained it out and it APPEARS that the cold start issues I had are gone.... I've driven it only once since and the ambient was 7 C... so not really cold.
The problem was, it went into "uphill maps" and was very reluctant to shift up for the first mile (after the first steep hill). Also, the shift from 2nd to 3rd was harsh.
Anyone with similar experiences?
/T
Old 04-17-2014, 08:39 AM
Had a 4 wheel alignment job done today - the toe was out quite a bit, both sides - one minus, one plus.... all others were suprisigly close to spec considering I have replaced all joints....
Tracks real straight and true now - a huge difference !
/T
Old 04-17-2014, 10:03 AM
theflystyle's Avatar
That looks brand new!
1994 SVX LSi
2008 Legacy 3.0R
Old 04-17-2014, 12:48 PM
Thanks! I ordered some POR-15 for the rear subframe, so it should look ultra-pretty when completed and be immune to rust forever. I'm also going to get my hands on some 3M urethane to fill in and stiffen the bushings. They're all in fairly good shape so I don't want to go through the work of digging the old ones out.
Old 04-17-2014, 01:29 PM
Yeah but you have them off the car, you might as well replace the bushings. You went through all that work after all . Then again I have no idea what the aftermarket is like regarding bushings for the SVX.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-17-2014, 10:43 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Created a very loud exhaust leak
Old 04-19-2014, 01:48 AM
Chucksta Chucksta is offline
Don't know if this qualifies as having done something for my SVX or not.. Bought a "donor" car a couple of weeks ago. Unfortunately not salvageable, but my SVX now has her own supply of spare parts that should get her five to ten years more.
I'm going to endeavor to send as little to the crusher as possible, I'm going to preserve, bag and tag everything that I can that I would foreseably use. The rest I'll post up for sale when I can. I'd rather that, than just see it slowly disintegrate. I can't tie up a spot at my mechanic's shop forever, but I won't throw away the irreplaceable either.
Old 04-21-2014, 10:18 PM
Ummm, bought a few more over the past few weeks. Including PhastSVX's former turbo SVX which will slowly be getting a complete overhaul to bring her up to speed over the next calendar year from now.
