Old 03-20-2014, 01:24 AM
Chucksta Chucksta is offline
@Gamesy... Lol.. But I'm in SOUTH Mississauga!
If it gets snotty out, there's still 4 snows on my '02 WRX..
I love the way the 18s' look and grip ( Hancook Ventus ), but I sure wasn't expecting the way it wants to climb up out of the ruts in the road all on it's own. The tires love flat pavement, any other surface requires a more "hands on" approach than I was used to.
Old 03-20-2014, 01:35 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Had a couple of pulleys changed on the Black Beauty, and converted from R12 to R134. Nice and cold again!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 03-24-2014, 12:01 PM
theflystyle's Avatar
Finally got both my babies in the new garage .... Cant wait to get my 4 post in next!!
1994 SVX LSi
2008 Legacy 3.0R
Old 03-24-2014, 10:47 PM
Drove it! Pulls to the right a bit and the steering pump(s) whine. I wonder if my guys put the right fluid in it...
I also committed to buying all the parts for the collision repair. Sorry guys, there isn't much left out there.
Old 03-26-2014, 10:51 AM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Originally Posted by 92 SVX View Post
my 6 speed swap is going quite well but still in progress, I could not get a pedal set from YT so I had to fab one up which has taken longer then expected but right now all 3 pedals are in I replaced the head gaskets/timing belt/water pump and all the seals associated. I was able to get a 07 6 speed with less then 8k miles and the ACT light flywheel with it.
Can you take pics? I still need to modify my clutch pedal set for my swap.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 03-26-2014, 01:23 PM
92 SVX 92 SVX is offline
ok here are some pics of the progress, I have some pics (thanks to icingdeath) of the modified pedals. which I will post up after the progress pics.
and the pedals
Old 03-26-2014, 01:24 PM
I will have to resize these.
Old 03-26-2014, 02:22 PM
Holy giant pictures!
For anyone who might need some, I took a bunch of pictures of my pedal set during my swap:
http://smg.photobucket.com/user/craz...?sort=3&page=1
Old 03-28-2014, 06:49 AM
Replaced the corroded battery terminals with new brass ones. The positive side was nice and easy, but the negative needs a ring terminal to make it nice and clean.
Im trying to narrow down the reasons why the battery kept dying.
1994 SVX LSi
2008 Legacy 3.0R
Old 03-30-2014, 03:22 AM
danielparker danielparker is offline
Swapped some Glass headlight lenses from a UKDM to a JDM..
I now have Glass headlights, with Fog lights!
So.. I placed my Glass headlights in a 200 degrees centigrade oven. First time around I left it for about 6 minutes. This was a mistake. While I extracted the glass lens OK, the rear was basically destroyed.
The 2nd was for about 4 minutes, and while the lens was hard to remove.. patience does it.
Then I cooked my JDM headlights. The first was for 4 mins, but this is too long for acrylic lenses, so they suffered some damage.
The 2nd was for about 2.5mins, and was 100% successful.
After cleaning the glass lenses, and the reflectors on the JDM lenses, I reassembled, the glass onto the JDM backs, and cooked for 2 mins each.
I how have glass headlights with all three bulbs working.
Old 03-30-2014, 12:21 PM
your lucky you didn't destroy the headlights, it should have been 110C temps for 5-6 mins
Old 03-30-2014, 12:29 PM
That makes sense.. I had read about 250 for 5 - 6 mins.. I now realise that was 250 Fahrenheit *NOT* Celsius. Anyway, it was a success.. albeit risky.
Old 03-30-2014, 03:40 PM
redlightningsvx's Avatar
Collision Refinishing Tech
Got an 04 forester ej255 turbo motor with wiring harness and ecu for $430 to put in my 99' forester. Can you say sleeper?
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 03-30-2014, 03:41 PM
The glass lamps are completely worth it. Hope you enjoy!
1994 SVX LSi
2008 Legacy 3.0R
Old 03-30-2014, 04:08 PM
Got my subframe stripped down and ready for cleaning. Next is dropping the tank so I can start on the brake and fuel lines.
