Old 05-31-2013, 03:47 PM
Tireiron Tireiron is offline
Re: Mid Engine SVX concept.
Why not use the subaru electronic DBW pedal and wire that in? Or does this card read from that electronic pedal? I have one of those pedal assemblies in my basement if you need any info from it.
Old 06-01-2013, 12:18 AM
Dessertrunner's Avatar
From my research I think the Subaru throttle system needs the ECU, also it functions on a single throttle were I need to control 6 of. For that reson the BMW actuator will be better, more power.
Tony
Old 06-02-2013, 05:01 AM
Okay got the throttle running on the test bench, so I will have to install it on the can later.
Old 08-21-2013, 02:47 PM
Just finished a balance bar that attaches to the brake booster. This means that we can adjust the brake balance between front and back wheel.
Tony
Old 08-21-2013, 02:48 PM
sketch sketch is offline
glad to see that there's still progress being made on this project!
Old 09-26-2013, 12:27 PM
The project will continue but I will no longer be posting on this forum as I have had enough of some memeber.
Old 09-26-2013, 04:11 PM
bishop bishop is offline
is there anywhere else we'll be able to follow? really wanted to see how this turns out.
Old 03-07-2014, 06:47 AM
Just to second this, does anyone know a forum that Tony hangs out on now? He's got some awesome projects going and I'm sure plenty that can benefit this community. It would be great to see how he's doing.
Old 03-08-2014, 12:56 AM
Hi Guys,
Most of the time I hang out on this forum
http://www.ozclubbies.com.au/
You have to regrister and you need to answer a question which is to do with a Lotus that was built to drive on the road and has been famous for 50 years. I find the forum good because there are a buch of guys that are experianced with engine and building your own car. Currently I am building this you can folow the build on he forum also me getting beatten up because I want to do things my way. At this time the engine in it is a Subaru 1.8l single overhead cam and 5 speed box. Due to the short stroke and big bore of the engine we are hoping to get it to rev to 10 to 13,000 rpm and develop some were north of 250hp. The build will have a total weight of around 500kg so it will be something like 2kg per Hp and be regristered for road use as well. I have got rods and pistons for the EG33 development that will give a compression ratio of 13.5:1 also pretty sure that we will get the EG33 to develop over 400hp Na may even get closer to 500. You never know the EG33 may end up in the build yet its just that the 1.8l and gearbox is coming in at 100kg for the lot. Anyway come join us on the other forum when ever you feel inclined
Old 03-10-2014, 10:33 AM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
All,
For what it's worth, the OZClubbies site that Tony is on might just be full of more "characters" than the SVX Network
Cheers,
Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 03-14-2014, 09:31 AM
BRZCory BRZCory is offline
Here I was hoping for an update, only to be saddened
Old 08-10-2014, 10:46 PM
Suberdave Suberdave is offline
about 2 years ago i sold my SVX, so i dont get back to this forum much.
however i had this same idea and was going to do it in an SVX but instead opted for an older GL coupe. and sold the SVX rather than cut it up.
I still used a EG33 from the junk yard. built a manifold to adapt an Eaton M90 Super charger to it, i opted for a 5 speed rather than the auto. (makes it much more fun to drive). and i am running a full stand alone Link G4 Extreme.
well here it is. it has been up and running for about 2 years now. took it to the drag strip and put down a 13.9 @ 101mph. on 205mm street tires, hard to keep them from spinning. on a dyno jet she put down 254RWHP and 270RWTQ.
Pics:
Videos:
http://youtu.be/dNQR40rblwohttp://youtu.be/dNQR40rblwo
http://youtu.be/0BEsow9v5Tw
more pics.
http://wordpress.suberdave.com/?page_id=335
Dyno:
-=Suberdave=-
www.suberdave.com
Old 08-11-2014, 07:04 AM
Wow Subi under glass
Old 08-11-2014, 08:15 AM
Me Likey.....
Old 08-23-2014, 12:16 PM
SuberDave that is one hell of a build, a job well done. Is there any chance of getting a copy of your Link G4 program as I am using the same ECU please.
What have you set as your maximum revs?
Tony
