#196
Re: Power Mode Selection
It's just weird that none of them work even though the other six bulbs are good. Makes sense that D would be out. It's the bulb that's lit the most ![]()
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
#197
i would start by removing the aftermarket alarm. if it's anything like the usual best buy hack job install then it's likely to be part of your problem.
#198
#199
![]() I'll have to check a wiring diagram to see where the illumination control is. I mean dimmer control. Thanks for the tip Harvey.
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 Last edited by SVX8588; 02-17-2012 at 09:00 PM. |
#200
Are there any photos for the instalation with the switch? The first posts photos were removed.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#201
hi, just wonder if this would be a workable switch to try to make this mod look as stock as posible. i have a ob2 with out a light and this switch is lighted so i will no it on.
http://www.ebay.com/itm/NISSAN-PATHF...sories&vxp=mtr |
#202
Can someone clear up the installation process? After reading 41 pages I got lost
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 05-19-2012 at 09:20 PM. |
#203
Even put a switch in between it because you certainly don't want to be driving in power mode while on the highway but after about 3 months of using power mode during regular driving my transmission died. Can't really say this did or did not contribute to the premature failure of my transmission but I'm guessing it sure as hell didn't help anything. If you're going to do it, just ground it like I did with a switch in-between somewhere so you can turn it off when hopping onto the highway... don't make it harder to install if you don't have to. Granted, you'll definitely be more compelled to drive the SVX a lot harder with the power mode because it's just so much more fun to do so.... that could have been the actual reason behind my tranny kicking the bucket as well. You tend to just take advantage of it after it is installed and drive the **** out of it.,,, as I did. ![]()
1994 subaru svx le 112k |
#204
I did the install but I got no Power light. It lights up on start up, but not when I use the switch. I hooked up A4 to a toggle switch, then to the blue wire under the kick panel. Am I doing something wrong? Do I need a specific type of switch?
#205
Try connecting the pin directly to ground (any metal part of the car basically). Maybe you have a bad connection somewhere. You don't have to actually put in on the blue wire, anything that's grounded will work. Any kind of basic switch will work, but post a pic of the switch so we can take a look.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#206
I still need to do this..
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#207
Run a wire from the other side the switch to a piece of metal frame in your car. I used a ring terminal on one the bolts under there, I think it may have been the one that holds the TCU bracket, it was one them easy to get to bolts under there I used. |
#208
I removed the connection from the blue wire under the kick panel and used the metal frame of the car. It works!
![]() Thanks to all for your help! I will test it tonight. Another question: when should I use it? When passing, getting onto the highway, going uphill, etc? ![]()
#209
#210
Under 50 mph, I drive with the shifter in 3, with power mode on. If I'm cruising above 50, I put the shifter in D and turn power mode off. Sometimes on the highway if I'm trying to pass or just generally in a fast mood, I'll turn power mode back on. Cruising along in 4th with the torque converter locked up gives really good gas mileage, but it doesn't lock up until 50. And, driving below about 45-50 in 4th is not ideal for the stock transmission.
