#166
Re: Mid Engine SVX concept.
Not sure on the exhaust.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#167
Hi Guys,
A lot of questions so if I don't answer all please ask again. The exhaust and sump were there just to show how much lower the engine is they are not to be used in the final. - Current oil filter position is dead being moved up top and the exiting housing milled off. Dry sump pump will be on top of motor and changed to 3 stage. 2 stages sucking from sump and pressure to block. Oil will be feed direct to the top two galleries on the top of the block. - Water pump will clear just, will be a slight dent in the tube (heat and dent) for the water pump and the CV joint onto the gearbox. Every thing is right on the limit to enable the engine to go as low as possiable. - Engine mounts are pretty solid as are the new gearbox mount I am currently building. - Bill I am of 2 minds on the Corvette arms, while they fit well I need to have a steeling arm on the upright due to the corvette arms having bottom ball joints. It makes it more difficult for me to keep the correct angle when the wheel moves up and down. They do fit well and they look the part so maybe I just need to get my head around them a bit better. - Harvey my jump in here but I am going to narrow exhaust pipes for the first 400mm in stead of 1 3/4 I will do it in 1 1/2 then into a 3in pipe. My logic is that I want the velociety in the pipe to have a hi scavenge effect to get the last bit of gas out of the cyclinder at hi revs. The small pipe will only make it harder when the valve first opens which is the time the exhaust has the most power. Hope that covers all your quetions. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#168
#169
Tony
#170
I'm in the process of dry-sumping an EJ20 and I'm also using a 3 stage pump with 2 stages of scavenge direct from the oil pan. My initial plan was to run the oil pressure feed directly into the factory oil filter location and then use a remote mounted oil filter.
After mocking everything up, I decided it was all too messy and now I using the factory oil filter in the factory location. I'm running the oil pressure feed into the bottom of the (gutted) oil pump so that the oil flows straight to the filter and then follows the oil path as designed by FUJI. Your idea of running the pressure feed into the top of the block intrigues me as it would suit my high clearance objective and save lots of custom work on the oil pump housing. I did think of it early on, but couldn't guarantee it would work, so dismissed the whole idea. I'm keen to see if it works for you. |
#171
Hi Brumbyrunner,
I have the design of the oil pump so I can take it fully off and bolt a blank plate in its place. The oil filtes nipple can be removed and a 14mm plug installed. How are you going to drive the pump? Also what type of pump are you going to use? The Dailey I am goiing to use has a pressure reg on its ass next to the pressure pump. Tony
#172
The oil filter thread is M20x1.5. I'm using a nipple to fit a genuine oil filter straight up to the block without the factory oil cooler. I bought a 3-stage Peterson oil pump, it has an integrated pressure relief valve. Looked at Dailey and Nutter which both have good reputations but these guys had the best range and service. Last edited by brumbyrunner; 01-24-2013 at 04:49 AM. |
#173
Brumbyrunner,
What water pump are you running and is the thermostate still in? Tony
#174
Just want to point out, in case you didn't notice, he's working with an EJ20, not an EG33.
#175
I already realized it was a different engine. Tony
#176
No thermostat. Coolant flow is controlled by an electric pump. Standard non-turbo radiator, mounted in the back. Runs very cool. If I leave the fans on at idle, the temp will come down to 40*C. |
#177
Did some mods to the other dry sump so it can be used on this job. On the mid engine I am only going to worry about 3 stage pump.
Here it is. Tony
#178
Looks great. I love this thread. Got any pics of the other side?
Looks like both suction ports are going to be pulling from the same area. I would think it would be better to have one at the front and one at the back? Or on either side?
#179
Its more about pulling the surge volume out when it comes in from the heads when the car changes direction and have the high capicaity.
Here is the top side. Tony
#180
Okay I have been busy here are some shoots. Milled the upright from a 37kg block of steel down to 3.4kg. This means I can use the front axles in the rear of the car.
Tony
