#166
Re: 11:1 CR Race/Street Engine build
-Bill
#167
Sounds good Tom...reminds me of mine.
M |
#168
That sounds incredible.
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
#169
Greetings from Dubai. I heard it all the way over here. I'm going to have to pussy foot around the neighborhod so I don't break any windows.
Tom, sounds really good. The in-line thermsotat also sounds like a good idea. Where in he circuit would you be putting that. I assume upstream of the radiaor, to get the warmest water. Danny: If you read this thread, sorry I didn't reach out to you while I was here. I was totally booked the entire time. Didn't even have a chanced to go skiing. I'll try to touch base next time I'm here.
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#170
Dubai and skiing mentioned in the same write up....ah, what an over abundance of wealth can do to a country Safe travels, Dan! -Bill
#171
What have you guys done about the power steering pump. At high revs it will boil the oil?
Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#172
Outlaw Engineering underdrive crank pulley. Chromed and beautiul.
#173
Tom |
#174
#175
How much smaller is the pulley,
Also does your radiator still have the auto cooler as you can put the power steering through there. Tony
#176
Tom |
#177
Just ordered 4 new Frozen Rotors:
#178
Do you have a source for these other than Frozen Rotors' website? At $600+ for the set...I like good parts, but that's a little steep for me.
#179
Power Slot used to have a rotor that wasn't cryo treated for about $110 for fronts, but I checked their web site and they don't list it. You might contact them.
#180
Okay, I'll keep an eye out.
