Old 03-02-2013, 09:36 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
Very nice pearly. Makes me miss mine... I like the euro tail bar, looks great. Digging JDM corners too; I have them on both of mine, they just look so much better than the stock ones. You have good taste, sir.
Thank you! Great minds...!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 03-02-2013, 10:59 PM
ShaneHobson ShaneHobson is offline
I collect old magazines with reviews of cars I own. Today the May 1992 issue of Car Australia magazine arrived in the post which features a four page write up on the Aussie version of the SVX. I'll add it to the stack. When I finally get my hands on a good flatbed scanner, I'll start uploading the articles.
Old 03-03-2013, 02:58 PM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Practiced making double-flared lines on spare brake line tubing but failed horribly. Anyone have any tips? The flaring adapter doesnt seem to be seating evenly and ends up bending the neck of the tube.
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 03-03-2013, 03:29 PM
Originally Posted by AlcyoneSVX View Post
Worked on the Pearlie today. Installed my glass Euro Headlights, Clear Corners, polished the Waterfall Grille and installed the rear Euro Center Light Garnish!
http://www.flickr.com/photos/93691199@N05/8522293497/
http://www.flickr.com/photos/93691199@N05/8522301593/
http://www.flickr.com/photos/93691199@N05/8522300633/
Sorry about the links to the photos. I'm having issues with Photobucket.
where did you source the headlights?
Old 03-03-2013, 06:15 PM
AlcyoneSVX's Avatar
I found them on Ebay last year. It turned out to be Scoobymal here in the forum!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
Old 03-06-2013, 11:16 AM
SVX92-97's Avatar
SVX92-97 SVX92-97 is offline
Got my svx back from OT's after nearly a six month sabbatical. Tom just wanted to publicly thank you for putting a SMILE back on my face.
1995 POLO LSI 76K MILES SOLD
Old 03-06-2013, 11:44 AM
Originally Posted by SVX92-97 View Post
Got my SVX back from OT's after nearly a six month sabbatical. Tom just wanted to publicly thank you for putting a SMILE back on my face. Driving a rolling wet dream now.
YOU CALL THAT A SMILE? I remember your comments on your (sometimes 100mph) return trip to CT. Sounded more like
Old 03-06-2013, 12:07 PM
SVX92-97's Avatar
100MPH never felt so smooth and effortlessly.
Old 03-06-2013, 12:32 PM
100MPH never felt so smooth and effortless.
= sorriso di merda
Old 03-06-2013, 04:42 PM
Oh yea! They feel better above 100 . Although I will stick to the speed limit.
U R a lucky man that you didn't wait for the weekend to get your baby. You could have tried out he 4 wheel drive furrrr sure !
Old 03-06-2013, 08:17 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Most likely you have too much tubing above the clamp. The base of the adapter should have a shoulder that is the same height as how much tubing should be sticking out. You are flaring with the adapter first and then the 45 degree taper after, right?
P.S. make sure your cuts are perfectly square. Use a sharp tubing cutter.
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 03-08-2013, 04:37 PM
bishop bishop is offline
picked up an 05 lgt 5speed, lsd rear diff, and drive shaft, the guy threw in a stage 1 2.5rs clutch.
Old 03-09-2013, 05:43 PM
kinz kinz is offline
Went to the local pick n pull. Got a non droopy visor, Center console door, front license plate bracket, and the center brake bar.
On the way back I saw a fellow SVXer. I'm guessing their the one that pulled off a bunch of other pieces.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 03-09-2013, 07:12 PM
Bishop sent you a PM you also need a pedal set
Old 03-13-2013, 08:09 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
TRUNK STRUTS!!!
(By Lift Supports Depot)
Kit came with perfect stroke and strength struts, and short low profile mounting bolts. Only took me 30 minutes, a couple of wrenches, and a drill with a 1/4" bit.
It's definitely worth the $20 more than you'd spend at the hood strut website.
Also made a trip to the junkyard, as you can tell by the intake snorkel in the picture.
Mine's full of cracks and broken nipples
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
