#1621
Re: SVX Engine cooling "Again & Again"
I said we being Steve Jones and I tried to figure out how to drill the impeller on a existing SVX pump. The 3/4 Hp was in the thesis not Davis Craig. Get your fact straight before you fly into people.
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#1622
The pump in the thesis was simply there to provide a flow rate / pressure with an AC powered water pump - why, because it's easy to setup, same as when I used my spa pump to test flows. The pump in the thesis was 1 hp (750W), say 110V, that's still only 7 amps, my bloody AC/DC inverter would run that! Last edited by bazza; 09-25-2013 at 11:23 PM. |
#1623
Bazza is incapable of admitting that he was wrong, not a chance because his got all the answers. I will no longer be posting or even opening this forum, Bazza should have been kicked off when he flamed Harvey last year.
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 09-26-2013 at 12:24 PM. |
#1624
+1. ![]() Harvey.
#1625
My mate with his now 1000 bhp EG33 finally found the cavitation issue as I've already said and he went to an electric water pump to solve it. Now above I've simply said that if the electric pump is 500W then it will be 41A.... you asked what alternator would run it and pretty much any modern Subaru one will. I actually checked and found that my last race setup with electric water pump and 2 x 16" Davies Craig thermo's were sucking 40A - so i know it can be done first hand. As for me being banned - why? Because I don't agree with most things you and Harvey say? That's the whole idea of an internet forum. I recall Harvey busting my balls over numerous things including the 272 cams and you busting my balls because I was using an AC 240V pump (like the guys in the thesis) to do my testing. Then every step of the way for my own testing you were busting my balls and coming up with excuses why my testing had different results to your own. Stop being a hypocrite. |
#1626
![]() Quote:
"The things you own end up owning you. It's only after you lose everything that you're free to do anything." 92 Pearl White Ls-l (138k) Euro Headlights & Blinkers, 97 Grill, Euro Tail Lights, SS Brake Lines, Stebro Exhaust, Slotted Rotors, Classic Registration 96 Legacy Outback (206k) 5-speed 2.2 Lightweight Crank Pulley, Group N Trans & Motor Mounts SOLD Wanted: Steering Wheel |
#1627
Tapani sent me this today, very interesting, talks about the electric water pump and how to control it:
http://www.youtube.com/watch?v=Sobfh...ature=youtu.be This one also, very good: http://www.youtube.com/watch?v=nrfux...ature=youtu.be Last edited by bazza; 09-27-2013 at 08:23 AM. |
#1628
I can't understand what tony desertrunner is having a brain fart about
92 pearl SVX about to revive 92 Black 4ws (Jap spec) SVX 93 black SVX 93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear 95 bright red SVX 96 emerald pearl SVX about to revive |
#1629
He got butt hurt by being contradicted too many times and argued with so he is handling it like a mature adult would on the internet...
It's the internet, you have to handle peoples thoughts and opinions with a grain of salt and cant take offense by them. |
#1630
You can't have ideas and not have them challenged
#1631
Bazza, that's cool
![]() ![]() Here's a vid showing how to replace the EWP and the thermostat on a late model beemer. http://www.youtube.com/watch?v=o-BpUzAemyQ I'd like to point out (again ![]() With an EWP and no thermostat you will introduce low temperature coolant from the rad outlet and if you control the EWP based on engine ext temp you will compromize the basics of the Subaru engineering built on low delta T, controlling engine inlet temp, by pass flow passages, relatively high flow rate and flimsy radiator dimensions. You may be fine in a race car - just play around with radiator area to balance the system. For a daily driver all this is very different, especially here up north ![]() Tapani Last edited by Tapani; 09-30-2013 at 08:54 AM. |
#1632
Yea but there is a respectful way of challenging someone. But I think what got to him was the constant challenging of his ideas, almost nitpicking even, where he had to spend a lot of time defending his ideas and not a lot of time making progress. I can see how that might get frustrating. People like to play "gotcha" too, when someone makes a little mistake, and that can get annoying real fast.
But Tony's following rule #1 of internet forums: If it stops being fun, stop going there. The flip side is that if you want people to stick around and talk to you, you have to make sure they're enjoying the conversation as much as you are. Text doesn't always convey tone/emotions very well, so you should always try to keep your side of the conversation nice and clear, so it can't be taken the wrong way. It's how people act toward strangers in real life, so it should be how you act with strangers on the internet. Tony has a blog somewhere, right? I hope he starts/keeps posting his projects there. Because we are definitely worse off for his having left.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#1633
What if the stock water pump pulley is replaced with an idler and the wp shaft then run by an external electric motor (thru the idler)?
We might opt to forget about the physical constraints (space, final arrangement etc) for now - just try to come up with as many ideas as possible how that could be demonstrated. Another way to use the OEM pump is to redirect the belt around the pulley and start with this. Concentrate on the "hows" and forget the "why nots" for a start ![]() Look at the photo and just kick around new ways of thinking ! Tapani |
#1635
Someone may have already asked this but couldn't you change the size of the oem pump pulley to increase flow
