Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania
Old 01-30-2003, 02:16 PM
1994SubaruSVX 1994SubaruSVX is offline
Lowered SVX
landshark.......
i went the spray can route at first and it lasted about three months. the brake dust will simply destroy the paint in no time. when the paint fades in color, bubbles, and then cracks your calipers will look like doo doo.
1994 SVX, true dual Magnaflow exhaust, K&N filter, 17" Enkei RS6 wheels, Bridgestone Potenza RE730 225/45/17 rubber, zinc plated cross-drilled rotors with yellow painted brake calipers. B&M tranny cooler rated at 19,000 GVW. GC springs and Koni strut inserts installed and the car is lowered two inches all the way around!!
"Too much fun to drive!"
Old 01-30-2003, 03:08 PM
sfsvx's Avatar
sfsvx sfsvx is offline
Yeah, it's a poodle - so what?
Originally posted by mohrds
I have a powdercoating oven that is not used for cooking food.
Doug
J/K about the oven.
I'm definitely interested - will be back with you when I figure out a color.
Dick
1999 Legacy GT 30th Anniversary Edition
2001 Outback Sport
Old 01-31-2003, 09:29 AM
hotshoe50
neat thought but???
I checked out the pics and also the prices that were quoted for doing the job...
Call me crazy but thats an expensive pretty face and those are really mediocre calipers to invest so much money in. The 2 piston fronts are so small and only push against the rotor from one side and the single piston rears are really really small.
No wonder these cars don't stop well...
If it were me and I had to have colored calipers, I would clean them myself and use the Duplicolor spray kit for calipers or the epoxy brush on kit (either are well under $40.00). The brush on is not as smooth but either looks good. I would then put what I saved into the Kitty to buy a set of Brembos: a lot more bang for the buck than powdercoating
Thats just me tho'
Hotshoe
As an aside, I bought a pair of Indy car calipers for my Misu for $125. and a pair of new slotted 13" rotors (no centers) for $50.00: both on eBay...it can be done for less
Old 01-31-2003, 11:02 AM
mbtoloczko's Avatar
sans SVX
I used to think that the brakes were lousy on the SVX. When I first got the car, I had to practically stand on the brake pedal to get the thing to stop. Then I had all the rotors turned and installed Axxis Deluxe Plus (organic) brake pads. It stops beautifully now. My current theory is that the OEM brake pads just plain old suck. I do worry about the rotors overheating, but after a month or so of spirited driving, no problems with warping. The front rotors do have a bit of heat tinting though. :-)
Mychailo
Visit my locker
Old 01-31-2003, 11:25 AM
subafan subafan is offline
not just a fan, a Member!
hey doug
how long would it take to powder coat the calipers?? i'd love to drive the svx over and get it done and drive it back to madison if i can cram it all in a weekend or something!
Old 01-31-2003, 05:02 PM
Because brakes are so important (they stop the car) I decided to do the caliper powdercoat thing. Number one, they won't rust anymore, and they are rebuilt. When I got them off of the car, I found that mine were shot, and needed to be rebuilt anyway, so I got both things done at the same time. I also added the ss braided lines, and rotors at the same time. This should help also.
Doug does a very nice job of powder coating, and they are packaged for shipping so they won't be damaged. I am a very satisfied customer. Oh, and I am sure he will include a portion of dog drool is you ask nicely.
Old 01-31-2003, 05:07 PM
oab_au oab_au is offline
Re: neat thought but???
Originally posted by hotshoe50
Call me crazy The 2 piston fronts are so small and only push against the rotor from one side and the single piston rears are really really small.
Thats just me tho'
Hotshoe
OK, I'll do it, Your crazy!
You also need to learn how disk brakes work.
Only one side.!!!!!
One Arm Bloke.
Tell it like it is!
Old 01-31-2003, 09:35 PM
mohrds's Avatar
mohrds mohrds is offline
Fight Eminent Domain Abuse!
Send a message via AIM to mohrds Send a message via Yahoo to mohrds
Thats just me tho'
Hotshoe
I agree. If you have the money, upgrade the brakes. I'm only giving people the best looking stock brakes they can get. It is a lot of money, but it is almost all labor. I spend about one hour per caliper just cleaning all the years of grease off of them and getting them ready. If you paint them, you'll still be spending close to twelve hours disassembling them, cleaning them, painting them, installing new parts and reassembling. Add in the $50 for the rebuild kits and your right in the same ballpark.
Doug
1992 LS Touring (6/91) - Currently undergoing a five speed swap
Black over Claret with spoiler; 235,000 miles; Mods: 2002 Legacy 5 speed, ACT Pressure Plate, Excedy Clutch, Short Throw Shifter, Aussie Powerchip
Black over Claret with 2.5" setback spoiler; 202,000 miles; Mods: B&M Cooler
1994 LSi (4/93)
Bordeaux Pearl; 198,000 miles; Mods: Weight reduction.
1969 Mustang GT Convertible
1970 Mustang Convertible
2000 Ford Excursion
Sola lingua bona est lingua mortua.
Old 01-31-2003, 09:42 PM
mohrds's Avatar
Originally posted by subafan
hey doug
Well, If we stay up all night, we should be able to do it over a weekend Those things take a long time to cool down after being baked and they get baked twice.
Seriously, I work on an exchange basis, so we can have the new ones ready to install when you get here, then you can use my tools to install them here and leave your cores. Should take you about two to five hours depending on your mechanical ability. If you need me to help, that will cost you extra
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 01-31-2003, 09:46 PM
elninoalex's Avatar
elninoalex elninoalex is offline
Registered Abuser
It was totally worth it. They look awesome. Thanks again, Doug.
Stephen
92 Ebony - Level 10/n2o REAR-ENDED
92 Teal - painted yellow/4.11 5spd/n2o SOLD
92 Claret - 4.44 SOLD
94 Barcelona - FWD SOLD
92 Ebony - 3.90 SOLD
94 Laguna ROLLING w/4.44s/Ecutune ECU +TCU/STI springs/Infiniti M45 rims
Old 01-31-2003, 10:03 PM
Strictly Subaru
Hi, has anyone here found any aftermarket performance brake calipers that don't cost a small fortune? Or, is the small fortune really worth it.???? Any recomendations or feedback?...... I do have to admit, the yellow powder coated calipers look nice...
Old 02-01-2003, 06:22 AM
alacrity024
at this point in time, what're the details of this deal?
do i pay you, then you mail me the powdercoated calipers and i mail you my old ones when i switch them off? are the ones you mail me rebuilt at all? how much does this all cost? i'm too lazy to search through posts.. of course, this doesn't obligate you to cater to my needs, but i thought i'd ask
-adam
Old 02-01-2003, 08:55 AM
scottswaaley
Wha'ts the deal with the PC graveyard behind the calipers? It is sad.
Old 02-01-2003, 11:41 AM
mohrds's Avatar
Graveyard???
They are all up and running. That is my computer farm. The one on the left is my Citrix Server. The one next to that is my firewall/VPN server. The next one over is the active directory/exchange server. The one after that is the Home Automation server that controls the HVAC, lighting, and entertainment systems throughout the house. The one next to that is my WinXP test box and the one on the right end is my win 2000 test box. Not pictured are my two Thinkpad laptops, my Mac and my wife's workstation.
Doug
1994 LSi (4/93)
2000 Ford Excursion
Old 02-01-2003, 11:46 AM
mohrds's Avatar
-adam
You pick a color, I send you a rebuilt, powdercoated set COD for $300 plus shipping (~$340 total). You install them and return your caliper cores back to me in the same packing material. Then I inspect to make sure you sent everything back, then I send you a core refund of $100 via check or paypal. Total cost to you is about $260 with total shipping charges.
You are always welcome to pay me prior to shipping them out. It will save you the $6.00 COD fee that UPS charges.
Doug
1994 LSi (4/93)
2000 Ford Excursion
