Old 01-19-2003, 05:28 PM
subafan subafan is offline
not just a fan, a Member!
steering column prob?
how many positions can the steering wheel be set at? i know my telescopic adjuster thingy is working fine, but it seems like my height adjuster thingy only locks on the lowest setting?? anyone else has this problem?
Old 01-19-2003, 05:32 PM
The lever on the side is just a release, to tilt it up, then it pulls back to where it was set.
To adjust the height, pull down the lever on the bottom of the column, set it were you want it the push the lever back up.
Then use the release to lift it for entry/exit.
Old 01-19-2003, 06:32 PM
yup, the left side handle is just to make getting in and out of the car easier. works great, but i always forget to use it!!!
Old 01-19-2003, 09:30 PM
alltrac alltrac is offline
my 92 alltrac was nice when you turned off the ignition the steeringwheel automaticlty tilted to its highest position and it had memory for when you restarted it would go to were you last had it set at read your owners book it explains alot of cool **** for our cars also this new wrx sti is a new threat we need more aftermarket
Old 01-20-2003, 03:47 PM
yay!! after 5 months, i finally can see the meters and the road at the same time!! haha
you had a celica all trac? that's a nice car too... i had to go with a gt cuz i couldn't afford the all trac....
yep... we need more aftermarket for svx.... that seems to be said alot here hehe
Old 01-20-2003, 07:45 PM
Subafreak's Avatar
Superbeast
Re: steering column prob?
I don't like those automated settings, ever get into some 4'5'' old ladys fancy Lincon to bring it in for an oil change and the the seat starts to crush you into dash board as the steering wheel crushes into your groin? Very scary!
