Old 10-29-2024, 05:01 PM
Noriyasu Noriyasu is offline
Both great looking cars!
Thank you. I have so much to do and I'm tired, but I'm glad that my cars are in good condition at least.
Old 11-02-2024, 08:53 PM
Back in the garage tonight, working on the Group N motor mount install. Taking a break to run and get some drill bits and grinding bits to make my 1/4 inch spacer.
Old 11-03-2024, 01:04 AM
I started painting today. I think it's important for amateurs to paint carefully and take their time.
Old 11-03-2024, 01:35 AM
I completed the Group N engine mount install tonight. I've been cleaning under the hood and under the car as I'm approaching each repair. It's looking great so far.
Tomorrow, I'll continue working and move on to the rear differential mounts.
Old 11-03-2024, 02:17 AM
The shape of engine mount seem to be a okey. By the way, isn't the cross member a little oily? Is there any oil leaking from the rear main seal?
Old 11-03-2024, 02:28 AM
You're right! I've been cleaning up the crossmember and underbody from evidence from previous oil leaks (that the last owner's mechanic repaired.)
Once I drive the car more, I will determine what still needs attention.
Tomorrow, I hope to replace the differential mounts, PCV valve and hoses, and a few other details.
Old 11-03-2024, 07:01 AM
SVX_MY_BABY's Avatar
Looks good to me. I can't believe it's so clean. Mind you. Mine has 30+ years of 'Rust Check" built up on it.
Peter
Old 11-03-2024, 04:22 PM
If it's been repaired, good news.
The mechanic would have removed either the transmission or the engine when he replaced the seals. It would have been much easier to clean the subframe at that time, and that would be the best timing to do so.
There is a long, narrow cover at the bottom between the engine and transmission. It is narrow, but you can remove the cover without removing the engine and transmission. If the seal was leaking, the inside of the cover would probably be oily as well. You can remove it and clean it. I think it is held on by four M6 bolts.
From what I recall, the cover comes in two parts and you have to remove one first to access the other bolt.
Old 11-03-2024, 04:31 PM
The transmission was removed to swap with a 4.44 unit by the previous owner's mechanic. The seal may have been changed at that time. I have found myself cleaning up after a few things the last mechanic worked on.
Old 11-03-2024, 07:39 PM
When servicing a car, the thing that usually takes me the most time is cleaning, and I would expect any good mechanic to do the bare minimum of cleaning.
As you know, natural rubber expands and deteriorates rapidly when exposed to volatile oils such as gasoline and diesel. Engine oil does not deteriorate as much, but it can harden the rubber and cause cracks. With the exception of special rubbers such as oil seals, it is not desirable for oil to adhere to rubber parts.
The engine mounts on my SVX have over 130,000km on them and are still fine. I think the leaking oil is damaging the engine mounts.
Old 11-03-2024, 10:20 PM
Agreed! This is why I usually clean the wheel arch and undercarriage of each car I get. Many older cars in the US often have either a coating of fluid leaks or rust. I may look to do a complete steam/degrease underbody wash in the future. I have done this for my other cars and I am always happy with the outcome.
Old 11-05-2024, 01:44 AM
Worked on the 92 SVX again today. Reinstalled the exhaust, filled the transmission and differential, changed the sway bar bushings up front and a bent end link. Moved onto the clogged PCV and noticed a couple cracking vacuum hoses.
I then decided to pull the manifold, replace the brittle and cracked hoses in the spirit of doing the job properly. I will also replace the knock sensors as they are both cracked, and the short coolant hose that attaches to the water pipe, under the manifold. I will also replace the short 3 inch fuel injection hose on the manifold. Replacing these parts will mean better reliability and peace of mind.
I am getting excited at the idea of driving this car again soon!
Old 11-05-2024, 04:53 AM
Just a little more work. I am getting excited too.
Old 11-08-2024, 11:16 AM
Hooray!
Replaced all hoses underneath the manifold and the fuel supply, return and vent hoses. New PCV and knock sensors.
Test drive went well! Today, I am taking the car over to the tire shop for a wheel alignment and to mount and balance 4 new Continental DWS 06 Plus I grabbed from TireRack.
Old 11-08-2024, 04:05 PM
Hooray!
congratulations!
