Old 03-03-2023, 12:20 PM
jkp jkp is offline
OBD1 scanning
I have read ( but not completely understood ) the tech articles regarding diagnostics and my `94 SVX . I`m spoiled with my pocket scanner and OBD2 cars . Am I correct that after finding the yellow socket under the dash , I will need either a SSMI cable or ( VAG ? cable ) and then connect to a PC or laptop . I would then need to download a program to interpret the information . Am I on the right track ? Thanks
Old 03-04-2023, 10:33 AM
Noriyasu Noriyasu is online now
Re: OBD1 scanning
I made SSM2 scanning software for SVX. Please find following website.
http://grove-design-service.com/ssm/ssm_svx_en.html
This software can monitor ECU,TCU,AirControlUnit,CruiseControlUnit and 4WS unit.
ECU's of SVX uses SSM2 protocol except cruise control unit. CC unit uses SSM1 protocol. You can find detail of SSM in the "Diagnostics and Datalogging for Subaru SVX" website if you want to know.
Old 03-04-2023, 07:10 PM
Re: OBD1 scanning
There's a "how to" for reading the codes with no cables, laptop or scanner. It's on the site somewhere.
I have it printed, I'll see if I can find it.
Old 03-05-2023, 02:46 AM
Re: OBD1 scanning
Yes, self diagnosis function is more easy to know get trouble code.
You can know the trouble code by blinking pattern of the check engine indicator.
Once you tie blue cable (it tie to body ground) into 2pin of 9pin black connector (B83). for example, if you get 2 times long blink and 3 times short blink, trouble code is 23. It means air flow sensor related trouble.
https://minkara.carview.co.jp/userid...ote.aspx#title
Old 03-07-2023, 10:20 AM
jkp jkp is offline
Re: OBD1 scanning
My car is in storage until the end of winter . But , as I recall , it never blinked , just came on . Or , maybe because I was not looking for a blinking pattern, I did not notice . What struck me strange , it light can go out within a few miles of going on , unlike more modern OBD2 .
Old 03-07-2023, 12:12 PM
Re: OBD1 scanning
The light does not blink until you do the code reading procedure. It then flashes long and short to give you the code number.
Old 03-07-2023, 03:48 PM
jkp jkp is offline
Re: OBD1 scanning
Got ya . I guess I`m a slow learner
Old 06-24-2023, 04:30 AM
svxnavyvet svxnavyvet is offline
Re: OBD1 scanning
Hello I have a Subaru select monitor ssm1 and many carts I'm looking for a manual on how to run it.
Any help
Thank you
Jim
Old 06-29-2023, 10:18 AM
Re: OBD1 scanning
Hello svxnavyvet,
Do you have Windows PC ?
It's windows application. you can download zip file. And, extract it to any folder in your PC.
You just need to clock SelectMonitor_for_Windows.exe to run it.
Please note that you need to use SSM1 cable which uses FT232R device to communicate your SVX.
Please reply if you still have any question.
Old 06-29-2023, 11:13 PM
Re: OBD1 scanning
I run a Mac. but have a pc just for doing this. Just not good with them. I have the cable and have down loaded all the file for the pc onto my Mac. but not sure how to set up the PC.
Hello svxnavyvet,
Old 06-30-2023, 02:34 AM
Re: OBD1 scanning
Hi,
If you have only MAC (you are running MAC OS on your PC), you need use virtual PC like a virtual box "https://www.virtualbox.org/" to run Windows.
If you have Windows 10 or 11 PC, just need extract .zip file and click .exe icon.
I will add some description how to setup application with some picture.
I'm working on Qt programming for Linux application at work now. Qt applicaiotin seems to work on MAC. I may be able to make an application for MAC in the future. However, it won't be in the near future.
Old 06-30-2023, 05:25 AM
Re: OBD1 scanning
Hi,
See this. I hope it is useful for you.
https://grove-design-service.com/ssm...nstall_en.html
