RIP power steering?
Hello - after 22+ years of service, my power steering has stopped working recently. (LSL type) Seems like there is either none, or very little assistance.
Stuff I know: 1. Plenty of fluid at the proper level doesn't seem to be leaking. 2. Crank pulley is aluminum, so it's not the rubber thing slipping problem 3. Power steering light is not on. 4. Belt is tight, pump is spinning fine 5. No noises or such 6. O-ring was replaced a few years ago. 22 years is not a bad run, but what/how else could I check before replacing the pump? I suppose it could possibly be the rack. Neither have been changed since I got the car in Jan 2000. Thanks for any ideas
Re: RIP power steering?
My crank pulley is aluminum. (I had the slippy pulley issue years ago and got the aluminum one instead)
No squealing or other issues... It seems like I get a small bit of boost but not nearly what it was before.
You both should make sure the u joints from the steering column to the rack are in good shape. Resistance before the rack will never be overcome by assist from the rack
Tom |
My '92 got really stiff at slow speed quite suddenly. I found a wire hanging down under the dash near the TCU. When I reconnected it my power steering worked again. It was obviously a wire for the speed compensated steering.
I also had stiff U-joints on the steering shaft. They made the steering very notchy.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 05-07-2022 at 03:38 PM. |
I lubed them. First with WD40 and then oil. They were good for quite a few years until I sold the car.
1997 Bordeaux Pearl, 2006 Alfa Romeo Brera 3.2 6MT, 2010 Mercedes Benz GLK350, 2018 BMW 640i GT Xdrive, 2012 Moto Guzzi Norge GT 8V, Last edited by Blacky; 05-11-2022 at 05:03 PM. |
Good stuff here.
1995 Caterham 7 Twincam 2002 Porsche 911 targa -- now with FSI 4.0L power! 2007 BMW 328i Cabriolet 2012 Tacoma 4wd v6 Access Cab 2013 Mercedes E350 4Matic Wagon 2005 STi - totaled after 10 great years 1994 SVX LSi 5spd - sold but not forgotten 2000 Legacy GT 5spd sedan - gone after 150K miles of bliss |
You are the best, man.
