Heated electric swivel side mirrors
Hi guys,
just looking at the possiblity of retro-fitting electric heated wing mirrors. In New Zealand we only got electric (glass only moving, with manual push body type) and I would like to go the whole way and fit what some others got. I have got the following - mirrors, just have to swap over outer colours. mirror timer, but no mating connector - so I have reverse engineered the circuit. thermistor controller, don't think I can get into this unit, hence need more info. Mirror heated switch In/Out position switch (similar to normal mirror adjustable switch) - but extra fuction. What I need is a circuit diagram from a CXW version of the car (unsure if this is an S3/S4) showing connector pin numbers and locations etc Now I presume that the timer/thermistor unit fits under the glove-box.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-11-2017 at 03:16 PM. |
Re: Heated electric swivel side mirrors
If you are not determined to make it factory, there is a mirror power folding circuit on you tube. Works automatically when turning the car on or off.
https://www.youtube.com/watch?v=C0Q02pww3kw (this is the one we used). https://www.youtube.com/watch?v=GygSmBjZsD8 (this is interesting).
"Peace is the flower of justice." |
I know how to wire-up for folding option, what I require is the info for the heated option, I presume it goes to the thermister circuit block ? but how to connect it up?.
1995 LSI, Added the following - Gear Firm-Up unit (that I sell) together with Power TCU ROM & Power switch, K&N air filter, SVX side badges (USA type), Rear Deck Blower (JDM type), Side front markers (USA type), Side rear markers (USA type), Middle rear light (USA type), USA OEM Fog Lights fitted into NZ OEM glass (NZ OEM headlights had only reflectors fitted) Full set of yellow (90SH) Polish bushes includes 15 min mod, R1 Concepts drilled/slotted/gold finish rotors & Red covered braided brake lines (both from Dayle at Motorsport warehouse), EBC Redstuff brake pads. Full SVX bra (only used for shows). Koni adjustable inserts fitted inside OEM strut body, Zoom lowering springs (2" lower), OEM headlight washers fitted. Last edited by SURTEESS; 05-18-2017 at 05:20 PM. |
Opps sorry.
ALSO
I would like to swap the glass out on one of the mirrors (it has slight salt/water damage) - does anyone know how to remove the glass from the swivel (U/D/L/R) joint ?.
https://legacygt.com/forums/showthre...or-195813.html
