#31
Is the racer back in AWD mode? I thought it was still running in FWD mode? -Bill
#32
I wonder how fast my car would go if it weighed 2,800lbs! -Chike
"Wise men talk because they have something to say; fools, because they have to say something." - Plato 2013 Cosmic Blue 5spd Evo X GSR 2006 Galaxy Gray 6MT RX-8 (sold) 2006 Steel Gray WRX TR (sold) 1996 Brilliant Red SVX L (sold) Last edited by Chiketkd; 08-20-2005 at 10:24 PM. |
#33
Yeah, It's been AWD for a while now.
#34
#35
-Bill
#36
#37
Re: Fastest SVX ever for 1/4 mile? Anyone know?
BUMP. Any other list like this? I keep seeing EG33's with huge power on the internet, but they're never in an SVX. :-(
-Steven 1992 SVX Purple and Black 5 speed swap SOLD *1993 SVX Silver and Black *1994 SVX L Barcelona Red FWD |
#38
Bueller...
#39
Still wondering.
#40
Young Toms silver shadow got into the 12sec area I believe. It is getting a new 3.7 motor put in it with lots of other mods will be shooting for the 10 sec area
there is good reading in here about it do some search on shadow machine |
#41
Who has YT’s car now, and what are the plans for it?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
#42
I do and working on the 3.7 motor to go in it along with a lot of suspension work. going to run the 3.7 in another car till it gets broke in then put it in the shadow with the supercharger
#43
I bought the Supercharger kit that JAYSVX had in CA and put it onto Icingdeath's rebuilt engine. I installed a Hydra and its in the shop now getting a new exhaust and tuned. When its done, i'll let you know how it turns out.
The shop estimates it can squeeze out about 350-400HP from it with 12psi of boost. We're also looking at fabricating a new intake manifold to allow more air in. Rather than going up (due to the hood being in the way) they think they can spread the manifold out sideways to make more room for flow. We'll get to that after we get it running the way it is. If they can though, that will open the door for a lot more power. We'll see.
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
