Car not starting questions
My battery and starter both tested good at the auto parts store. I put everything back together and still won't start. No click or anything. I hear a click type noise coming from the back seat area when I turn the key over each time. I've heard that before. I noticed when I have the key in the whole area seems loose. The plastic molding around the steering wheel moves around like it is loose. Don't know if that if abnormal or something is loose. I have replaced the ignition lock cylinder a long time ago. Any thoughts appreciated in advance. I'm ready to have it towed to a local shop to trouble shoot it. This started after it rained for over a week almost every day. Inhibitor or neutral switch? I would not even know where to find it.
Mike ![]()
95 Pearl Blue L |
![]() Quote:
Any one of these can cause a 'NO START problem. 🙂 |
Re: Car not starting questions
Thanks for the in depth reply. Will check into these ASAP.
Mike
95 Pearl Blue L |
The security bolts that go through the ignition switch may have come out causing the looseness, it might even cause a no contact situation though I am unsure of that.
