Old 01-24-2010, 07:47 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: unfinished oem rarities list. Help me out you svx crazy people.
I could be wrong, but I believe these are a universal fit.
Wanted: Steering Wheel
Old 05-05-2010, 05:58 AM
I thought I would post it here. I finally found the Uber rare OEM Radiator with Aluminum tabs. I mentioned it quite a few times on the board, but no one seemed to know what I am talking about
I have seen it in person, checked its thickness and I can confirm that it is just the OEM rad + aluminum tabs intead of plastic. I don't know if it was OEM Subaru or just a modified from OEM.
Here is the pic:
And HERE is the link (just an SVX ad in Japan).
BTW, Earl you might want to note the Vin.
Old 09-11-2017, 03:30 PM
Go up.... lots of dust...
Guys need the part number of the headlights protectors. Trying something...
Thx
Old 09-11-2017, 04:26 PM
Thx
The only number on them was SCI 700204.
http://www.subaru-svx.net/forum/show...hlight=shields
14 years old and look as good as new.
Old 09-11-2017, 05:17 PM
My daughter had a '97 Outback with the same type of headlight protectors. They were fantastic. The headlights underneath were like new.
Old 09-24-2017, 02:49 AM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
OEM CD stacker holding bracket frame with SVX logo on the side, it fits at the base using the 2 holes near the side opening (where the antenna drain pipe fits) and then also connects to the actual antenna mounting point.
Note that my car has a removable door to get to CD stacker, other interior mats do not have this option - hence the add-on stacker holder that I am showing you.
Old 09-24-2017, 03:10 AM
SURTEESS's Avatar
Since someone has brought up the side indicator light mounted on the front wing, what about the non-USA front wing - without the indicator light hole, got to be rarer than the USA version?
