Old 07-26-2017, 02:43 AM
blue thunder blue thunder is offline
Strut Mounts
I am somewhat confused with what part number I need after going to different websites. I have a 95 SVX L and need at least the right front strut mount which is shot. I want to replace the front left as well if possible. Part number 20361PA000 is not in stock anywhere. Any help appreciated in advance.
Mike
95 Pearl Blue L
Old 07-26-2017, 05:07 AM
Re: Strut Mounts
They are NA. You'll have to find a good used part. Try these guys in Rancho Cordova CA. They are good to deal with and have about a dozen SVX parts cars.
http://sspparts.com/
Old 07-26-2017, 08:07 AM
SVX_MY_BABY's Avatar
Re: Strut Mounts
Perhaps Javan worked out a solution.
http://www.subaru-svx.net/forum/showthread.php?t=64355
Peter
Old 07-26-2017, 01:08 PM
Re: Strut Mounts
I have the koni strut setup up from motorsport warehouse with the lowering springs. So does this mean the STI strut mounts will work with my car? If anyone knows?
95 Pearl Blue L
Old 07-28-2017, 01:20 AM
Re: Strut Mounts
The part number I listed above is for the rear strut mounts. I need 20320PA011 for the front L/R. There are diagrams on here I found through a link in another older thread that show pics and part numbers. Whew. I will try to order tomorrow through my local dealership to get the parts faster.
95 Pearl Blue L
Old 07-30-2017, 08:23 PM
SURTEESS's Avatar
SURTEESS SURTEESS is offline
Re: Strut Mounts
I did the Koni inserts with Zoom lowering springs -
http://www.subaru-svx.net/forum/showthread.php?t=64292
