Old 05-23-2017, 03:10 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
1992 SVX LSl for sale
Location of the SVX: Brevard, NC
Year: 1992
Model: LS-L
VIN: JF1CX3538NH102898
Manufacture date: 6/91
Paint Color: Dark Teal
Interior Color: Gray leather
Miles:109,800
Options: all
AWD or FWD: AWD
Modifications: 4.44 transmission, chrome silver SVX hood ornament. Subaru 6-disk CD head unit (2003).
Major service: none except for transmission replacement. Spark plugs, drive belts and timing belts were all replaced at 60,000. Replaced power steering pump. New ft. struts, new polyy SB bushings, new ft. half axles, all rotors/pads done, new MAF, new cigarette socket, AFPR, B&M plate trans cooler, SS brake lines
Engine Condition: excellent
Maintenance Records: have all records since 5/96
Transmission condition: good
Glass condition: good (glass is tinted)
Type of tire and remaining tread: Vogue Signature, new 6/2016, 245/45-17
Type of wheels: Rota Boost 17” – good condition/ a few nicks
Interior condition: excellent
Body condition: very good to excellent
Known defects or problems: 1. Cruise switch can be sticky. Cruise is operational.
Comments about the car: I bought this car in March 2013 garaged since.. Prior to this is was owned by svxxx26 and Don/Jean Addington
interior is in new condition. The wear that is noticeable at all is on the driver's seat, and it is no more than well broken in - no rips or tears. I have Lexol'd all leather regularly. Carpeting is like new, always protected. Rear seat has rarely been used. The original radio/cassette was replaced with a 6-disk unit from an Outback. There is no rust anywhere
Low beams are HID, high beams are LED's with proper relays..very bright light throw. Starter mod done.
All fluids have been changed regularly. The oil has been changed more often than necessary and I have used Mobil 1 5W30 only. Likewise the front/rear diffs have Mobil 1 75W90. Paint condition is very good to excellent. There was some damage to the front fender and it was replaced and the hood wand upper half of the passenger door repainted by previous owner. The paint matches as perfectly as is possible. A few small dents were removed after I bought it. (per last owner's description..unchanged as far as new damage). I have continued to change the fluids regularly.
Of course there are a few small nicks and chips here and there
Svxfiles installed the 4:44 transmission after the original started having issues in March 2007. It had just over 60,000 on the odometer then. He also did the "$15.00/15-minute mod" and installed a modified dropping resistor (firmer shifts). Adjusted mileage due to gear ration difference is about 105,350.
Prior owners had a rebuilt power steering pump installed in November 2010. Tie rod ends replaced May 2011.
I would say that this is probably one of the better 1992 SVXs you will find anywhere. I know I have done as much as I could to keep it in like new condition like it's prior owners. Runs perfectly and has never failed me.
Asking price: $4,900.00, same price I paid for it.
Everything works..cold A/C, no SRS/ABS lights on.
Selling in hope of buying LAN's 1994 SVX..if I had more garage space I would keep it...if it doesn't sell I have considered a carport for one of my other cars and keep both. Picture shows RX8 rims with Blizzaks..Rota's on her now.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
Old 05-23-2017, 05:29 PM
Re: 1992 SVX LSl for sale
Beautiful car! Good luck with the sale.
Old 05-23-2017, 07:42 PM
fasteract7's Avatar
Merci....would love to keep both but space a problem. I get the feeling that I will solve that "problem" though and try to keep both unless someone pops up and realizes my "Teal Deal" is worth putting in their garage.
Old 05-24-2017, 07:05 PM
Invisible avatar
Thumbs up Re: 1992 SVX LSl for sale
I knew both prior owners, & I'll vouch for the excellent care they gave this vehicle.
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 05-25-2017, 04:44 AM
fasteract7's Avatar
Talking Re: 1992 SVX LSl for sale
Thanks for the comment. As the 3rd owner, I'll put my OCD behavior up against anyone else's !! See pic of engine compartment. I should put up a photo of the front subframe/suspension where I toothbrushed the grime away and Collinite waxed it...nothing some Zoloft couldn't fix.
