Old 03-30-2017, 04:34 PM
fasteract7's Avatar
fasteract7 fasteract7 is offline
Stumble at idle story/fix
Had the MAF failure like stumble/stall at stops with normal higher throttle response. Had fixed this problem with a new MAF a couple of years ago but suddenly returned. Got a new MAF just "cause" but problem didn't disappear this time.
Thought of a vacuum leak but hoses I could see were good. Closer inspection of the manifold intake plastic showed a crack on the lower PS side where there was a dual hose insert site, one for the valve cover breather hose. I guess 25 years of hot oil soaked vapors finally got the best of this plastic seam which seemed like a heat weld of the 2 pipes into the manifold body. Solvent clean, air gun dry of cracked area and hi temp RTV at crack site seems to be the fix.
1992 Dark Teal LSL, 4.44 swap, B&M trans cooler, AFPR, RX8 rims, 235/40-18 tires, SS brake lines, Hawk HPS pads, Strongflex poly ft/rr swaybar bushings, starter solenoid mod.
Old 03-31-2017, 09:23 PM
lsupcar lsupcar is offline
Re: Stumble at idle story/fix
Good info.
Thanks.
Any pics of the location?
Bill Z
Old 04-02-2017, 06:36 PM
fasteract7's Avatar
I'll take off the plastic cowl and get some light in there for a photo..should be able to see the red RTV sealant at the crack site.
