Direct bolt-on calipers
I've searched thru a bunch of these brake threads, and just so I haven't missed anything, there are NO upgraded calipers that will directly bolt onto the SVX, yes? I read one that said WRX calipers have the same bolt holes, but the SVX rotors are too thin and you'd have to get thicker rotors.
So again, there are currently NO calipers that are a direct, bolt-on replacement for the stock SVX calipers that won't require changes to anything else?
1997 Subaru SVX LSi Honda Accord wheels 17x7.5, 235/45s, 5mm rear wheel spacers; "3.3" and "AWD" badges on front fenders; AMR radiator/fans; lowering springs, s/s brake lines, drilled rotors; Stebro exhaust with quad tips, mid-muffler removed; tinted windows. |
Re: Direct bolt-on calipers
There is a project over on SVXNATION And HISE-TECH to bring over the 4-pot calipers, designed for the JDM SVXs.
4pot front/ 2pot rear, plus larger rotors, designed for the OEM 16" wheels. .
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
As far as I know the JDM SVX didn't use any other calipers, if so we could just put those on the usdm svx they didn't change any brake mount locations on any of the svx, it wouldn't make financial sense to do so. for such a limited number of cars, However that being said there is a plan underway for "cheap" 4 pot/2 pot to be made to fit
The first sets of calipers are en-route from Japan. For those of you inquiring about the brake upgrade kits Unfortunately they are being shipped PAL which can take up to 14 weeks to get to Philly.
That sounds all well and good, but right off the bat I wouldn't be interested in that, because the JDM calipers would have to come from Japan, and I'm sure they won't be cheap. What I'd be interested in is being able to take calipers off a WRX or something similar, and with minimal effort, bolt them right up to a stock SVX brake system. No bigger rotors, no changing hubs, etc. That, combined with s/s brake lines, should be a "Stage 1" brake upgrade. Simple, not very expensive, and something that won't require special tools or a lot of time.
I don't know if your famaliar with some of the wrx community happenings, but caddilac has a very cheap brembo that bolts up to wrx's with a simple adapter that is now easy to get, I believe with a adapter those cheap brembos should work with the svx |
Well now...
![]() Ryan Clark is an active svxnation moderator fellow eastern pa resident and personal friend of mine who is helping us with the 4 pot upgrades. Nothing usdm bolts up period... The JDM Legacy and forester Subaru 4 pots do match up and will fit under the stock wheel as well as the JDM GD 4Pot brembos. But- the brembos require 18" wheels. We can get JDM Legacy 4 Pots shipped to us for half the price of used Brembo calipers. Either caliper can be used with the stock rotors but will have pad overhang. The rear calipers require the correct backing plate swap in order to to bolt up. Let me know if you have any further questions in a format that is at least younger than my kids ![]() ![]()
. ![]() ![]() We are a combination of both the Network the Forums and a plethora of new bloods! We have close to 6000 members on all forms of social media worldwide. What's all the fuss about? We're just the next logical step in a social media-driven World! As one of the community's longest-running members explained: If the the traditional forums are the library... SVXNATION would most certainly be the popular corner coffee shop ![]() www.svxnation.com . Last edited by SVXNATION; 03-20-2017 at 07:06 PM. |
I think I also read somewhere that you also need to run 18 inch wheels with those Brembos?
I personally think 18s' are the best size though lol |
But on this car, 6-pots are probably overkill in stock trim. I have a 2004 Saturn VUE with the Honda 3.5 24V V6 with a 5-speed auto, and that vehicle is MUCH more responsive to drive than my SVX. I think the Honda 3.5 is rated at 250hp, so it has more hp than the SVX, but the VUE just gets up and goes without too much effort. On the SVX, it has a much more leisurely acceleration pace, unless you mash the gas pedal. That's fine by me, it's not really a sports car, more of a sports tourer, and for that it does a great job! I used to have a Harley Sportster 1200R, and upgraded from the stock 2-pot calipers to Wilwood 4-pots, and that was plenty of brake for that bike. I would imagine going with a 4-pot / 2-pot setup would achieve pretty much the same results on my SVX, all with fitting under my current 17" wheels.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
