Old 01-11-2017, 01:30 PM
Hangtownsvx Hangtownsvx is offline
need a new stock radiator fan
It seems like the only way to get a stock fan that does not use zip ties through the core is to get a $279 dealer replacement. Is that true? Any suggestions?
Old 01-11-2017, 01:37 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Re: need a new stock radiator fan
You could always try and get the AMR fan shroud. It comes with the two fans and the metal shroud
Old 01-11-2017, 02:38 PM
I don't see any shrouds or fans on their web site. The web site only lists WRX.
Old 01-11-2017, 02:40 PM
Sorry,
I do see SVX radiator for $635.
Do pancake motors use brushes? That my old motor could be rebuilt?
Old 01-11-2017, 05:11 PM
I see that my fan hub has cracks, the fan shroud is broken across the bottom, and the the motor squeals. This is equivalent to $347 in new parts. If I get a new after market fan, what should the CFM be and how would I hook up 4 wires at each fan. This is to replace the 5 blader not the 4. I assume the extra wires are for some multiple speed scheme.
280000 miles on the car now, but I am slowing down.
Ken
Old 01-19-2017, 02:23 PM
The 93-97 Nissan Altima fans are cheap enough that I bought a new pair installed on their bracket. The motor is almost the same, the mounting screw circle is a tad larger than the SVX requiring slotting the bracket holes by only 1/16 inch. The fan hub has a offset that is going the wrong way for an SVX. To compensate, mount the motor to the backside of the SVX bracket instead of the front. There is still enough clearance to the SVX engine pulleys. The electrical connectors are the same as SVX.
Old 01-19-2017, 05:20 PM
Good find.
Old 01-20-2017, 08:00 AM
SVX_MY_BABY's Avatar
There is a thread on here somewhere which was started a while back and was to list alternate parts which fit the SVX. Would be good to add this, but damned if I can find that thread.
Peter
Old 01-21-2017, 01:15 AM
Cotton's Avatar
Cotton Cotton is offline
Some Random Weirdo
I know they sold two of them on the FB page to people. Ask Jamie about it.
http://www.svxnation.com/products.html
https://www.facebook.com/groups/1668...c_ref=NEWSFEED
94 SVX LSI- Rebuilt engine, 4.44 with trans cooler, Quick Change Shift Kit, SS exhaust with Magnaflow muffler, 08 STI Wheels, K&N Filter, and still adding.
