Old 01-05-2017, 04:25 PM
alia176 alia176 is offline
Send a message via Yahoo to alia176
how to disable the ABS
Has anyone disabled their ABS? I just want to disable the ABS ECU and theoretically normal braking should still be functional. Just wanted to see if anyone done this before?
Thanks and please no debate about ABS functionality and all that.
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 01-05-2017, 05:56 PM
Re: how to disable the ABS
Just pull the fuse. The ABS light will stay on though. I've been driving my '92 with no ABS and the light on for 8 years.
Old 01-06-2017, 01:26 AM
bishop bishop is offline
Same as above, pulled fuse, removed right from gauge cluster, didnt work after the manual swap anyway. ABS on older subarus is far more hindrance than it is help.
Old 01-06-2017, 09:07 AM
Originally Posted by bishop View Post
didnt work after the manual swap anyway...
Is loss of ABS a normal consequence of a manual swap? My light came on after swapping my car but I just assumed I had goofed something up and never got around to fixing it.
Old 01-06-2017, 11:56 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Ours works on our 5MT SVX. Bought converted so no clue why it works on ours.
"Peace is the flower of justice."
Old 01-06-2017, 03:39 PM
Depends on the axle shafts I think, some subaru's have the tone rings on on the axle instead of on the hub so I think they may have been interfering. Doesnt matter at this point, when it did work ABS also most caused me to wreck more times than it saved me.
Old 01-07-2017, 05:35 AM
Ok, I pulled the 20A fuse so thank you for the confirmation. I'm heading to go skiing in the morning and hoping this issue is behind me until I figure out what's wrong with the right rear wheel sensor.
Thank you.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
