#46
Re: svx remote
Sorry it is dit , dit, dit, da ,da ,da ,dit, dit, dit
And dit , da da , dit is a call = CQ ![]() |
#47
Re: svx remote
![]() Harvey.
#48
Re: svx remote
#49
Re: svx remote
Hey blokes, don't gang up on a 70 something that learned ditty bops 48 years ago, I have a hard time remembering my email address.............
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! ![]() |
#50
Re: svx remote
going back to the pictures posted of the remote. The black wire should be attached to a metal plate that rests against the portion of the keychain (for added signal???)
did the remote end up working?
#51
Re: svx remote
My next major project is to find a 2003-04 Wrangler 2 door for all the great back country in Southern Utah. The ground clearance of the SVX won't work in sand stone country off road. It will become a semi garage queen.
#52
Re: svx remote
For sure! It is all about words...
#53
Re: svx remote
kwren, just curious, why did you post on a comment that is 5 years old?
Just curious. ![]()
#54
Re: svx remote
This is the only post I found about the security module, but my question was not answered so here it goes.
I have a 94 lsi, my security module is defective. The local yard has a 92 with the security module intact behind the glove box. Mine is under the rear deck. Are the modules the same or must I have one from a 94-97? ![]()
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi ![]() My fast baby: 2001 Suzuki Marauder ![]() My new baby: 2010 Subaru Outback ![]() |
#55
Re: svx remote
The same security module with identical wires and functions.Were moved in the later years because of the passenger side air bag. Also a more responsive antenna
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 ![]() 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback ![]() 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. ![]() 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . |
#56
Re: svx remote
I'm wondering if mine is as well. Thanks. Bill |
#57
Re: svx remote
Thanks for the info. svxcess.
I have no function of the security module, and the red light is always on. I am sure my problem was caused by a sticky driver side door lock. Each time I would hit the remote the door lock would react slower and slower until it finally stopped working. Soon after the alarm stopped working altogether and the red light stays on. I feel excessive current draw from the sticky door lock caused too much current flow in the alarm module and fried . I have since remove the door lock and cleaned it well, it seems to work fine now with the key.
[SIGPIC][/SIGPIC]Kenyatta The farther backward you can look, the farther forward you are likely to see. -Winston Churchill My baby: 94 lsi ![]() My fast baby: 2001 Suzuki Marauder ![]() My new baby: 2010 Subaru Outback ![]() Last edited by trueblue; 09-29-2016 at 10:57 AM. |
#58
Re: svx remote
Thank you true blue for that.
My remote works most of the time. Sometimes; however, the car will honk appropriately in response to the remote, but the locks will not respond appropriately. When I then use the key, the lock move easily and inside the lock sliders work easily. Thanks. Bill |
