Old 06-01-2016, 10:22 AM
alia176 alia176 is offline
Send a message via Yahoo to alia176
Timken wheel bearing - pre greased
Ok, just got off the phone with Bill from the Timken automotive section and he confirmed that the grease that comes with the Timken bearings are indeed wheel bearing grease. So, take them out of the box and install them.
Again, this is ONLY for the Timken brand bearings, I don't know about the OEM or other brands. I know lots of thread on this topic that are full of information, conjectures, etc but I wanted to post up this thread.
Timken automotive
1 866-974-6536
Timken bearing catalog link
http://timken.com/en-us/products/Doc...on_Catalog.pdf
copy/paste
1997-1992 SVX
front [qty]
Seal (Inner) ..............................................7102 29[2]
Bearing Assy (Inner) ..................................517007[2]
Seal (Outer) ............................................. 710231[2]
rear
1997-1992 SVX
Bearing Assy ............................................516003[2]
no seals!!
If it ain't broken it, doesn't have enough features!!!
'92 SVX LSL
'03 4Runner
'96 FZJ80 Landcruiser
'90 Mercedes 300E
Old 06-02-2016, 07:17 AM
SVX_MY_BABY's Avatar
Re: Timken wheel bearing - pre greased
Good to know. Thank You.
Peter
Old 06-05-2016, 09:03 AM
Austin Austin is offline
Fantastic! Thanks for posting this.
I did the find a distributor thing and there's a location that is basically right around the corner from me. I'll have to contact them to see about pricing on Monday.
Austin
__________
'97 LSi Ebony - daily driver - mostly just needs body work [couple o' rust holes, door dings, and peeling clear (of course)]
'96 LSi, Laguna Blue (retired - soon going to a new home)
'89 XT6 5 speed (Gone but not forgotten)
Old 06-05-2016, 11:03 AM
92 SVX 92 SVX is offline
I ordered the rear bearing and seal from Rockauto.com very reasonable priced, then I had NV Performance put it in they charged about $200 for the labor I was happy to have them do it since it needs a press.
NV Performance is just off Beach Blvd, 3115 Leon Rd
Jacksonville, FL
(904) 642-8120 if your interested.
I also wanted to let you know about something else but I forgot what it is. I am going to message you my phone number, I plan on going to the dragon meet in a couple weeks
Old 06-09-2016, 07:51 AM
A word of caution about the Timken seals, the ones listed in a typical online store like Rockauto, didn't fit the front. I ordered them, then returned them! Same thing happened at my local NAPA store, they're just too small. This is kind of weird but I had to go with Centrix brand of seals as suggested by other members so double check the front seal issue. I think the rear seals are more common size so maybe that's not an issue, I haven't ordered the rear bearings/seals yet but about to shortly!
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
Old 06-13-2016, 01:01 AM
Subbiedoo Subbiedoo is offline
So are you saying the timken frt seal PN's you listed on 6-1 DO NOT work? Correct? PN's for the timken brags are fine. Just makin sure
Old 06-15-2016, 11:26 AM
Check out the attached jpg of my Rockauto order. See how they state Timken 710473 Fits "front outer" or Rear inner. 710464 - fits rear outer and front inner. Umm, no way would they be interchangeable. The front seals are MUCH larger than the rear so I returned them.
But, Timken site link above should have the correct seal p/ns and I'd verify with a Timken tech on the phone before ordering them.
'92 SVX LSL
'03 4Runner
'90 Mercedes 300E
