Old 04-06-2016, 10:13 PM
92 SVX 92 SVX is offline
AMR Radiator install and Fitment
Ok so I received the prototype AMR Radiator today I took many many pics and showed each step in the install process. I hope you like it.
First was the un-boxing,
One of the first things I noticed besides the quality of construction AN Fittings for the transmission cooler lines.
I have a manual transmission so I didn't need to do anything with them but I spoke to Andy and he said the radiator will come with the AN to barb fitting,
So putting the fan shroud on the drivers side went on perfectly I did run into a little issue putting the passenger side shroud on though
Re: AMR Radiator install and Fitment
I wanted to get this installed and going and I have a spare passenger side shroud so I modified mine to fit.
I did the wiggle/jiggle to get the feet pegs set in and it dropped in perfectly.
There is lots of room between the fan shrouds and the engine for some of the more modified svx's out there
the view from the underside
I vacuumed out the system and it held great and refilled
A couple of videos of that vac and fill, and how good it cools
Old 04-06-2016, 10:15 PM
Old 04-06-2016, 10:48 PM
Some may notice that the top rad mounts are missing a bolt each, they are broke off, been that way since I had the car it never affected anything so I never bothered with it.
Old 04-07-2016, 05:15 AM
Blacky Blacky is online now
So the only problem is the fan shroud mounting points don't line up?
Old 04-07-2016, 09:10 AM
only the passenger side shroud, and not far off, I slotted out the tabs on the passenger side fan shroud so I could install it in the car.
Old 04-07-2016, 09:43 AM
theflystyle's Avatar
Thanks for the great update.
1994 SVX LSi
2008 Legacy 3.0R
Old 04-07-2016, 12:49 PM
You are Welcome
Old 04-08-2016, 05:38 PM
DallasSVX92's Avatar
DallasSVX92 DallasSVX92 is offline
Unhappy Re: AMR Radiator install and Fitment
Just paid....if this is my last post, it's beacuse my girl friend killed me......send help.
Old 04-08-2016, 06:38 PM
ok will do
Old 04-09-2016, 03:07 PM
jeskolesk jeskolesk is offline
I placed my order today.
Old 04-10-2016, 12:29 PM
I just checked out your videos. What type of coolant are you running?
1994 SVX LSi
2008 Legacy 3.0R
Old 04-10-2016, 04:08 PM
The long life Asian formula, its red, I don't really know much more about it, it was reasonable price at the parts store.
