manual shift rear mount question
Finally getting around to installing a manual transmission. Bought about everything I need from a guy who decided not to move forward. Read all the posts I could find on the forum and laid everything out today to see if it made sense.
I'm still a little unsure on wiring but think I can work that out when I get there. However, the rear shift mount has me puzzled. I see why it is needed and where it goes but I think I'm missing something. Right now I have the shifter, rubber boot and shift linkage. I see where the rear mount needs to go but I just have the shift rod. Is there a part that fits on the shift rod that is held by a fabricated bracket or does the fabricated bracket need to hold the shift rod as well as bolt to the car? I've seen several pictures on the forum of how others have done this, but have spent over hour today and can't find them. Thanks |
Re: manual shift rear mount question
Did you get this rear bushing?
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
I finally went to local dealer and had them printout parts diagram for WRX shifter and saw what I needed was that bracket. I ordered a new one.
Thanks for the reply. I think I'm ready to start this project. Really looking forward to having a manual. |
Awesome!!
I'll dig up whatever documentation I can find from when I did mine. I remember taking pictures and writing up instructions, particularly for the electrical stuff.
That would be great. I've spent hours searching the forum reading and printing things on manual installs. I think I understand most of it but I'm sure I will run into some issues. The first time for any project is a learning experience and this one has a lot of things to do.
I did convert to 4:44 a few years back so the transmission removal and install so I have some experience on that stuff and have spent a lot of time working on cars over the years. The wiring is still not too clear but I think once I get there and have the wires in hand it will make more sense. In looking at my pedals I see there are two switches on the clutch pedal, one at the top of travel and one at the bottom. I assume the bottom one is for the neutral safety switch, but the one at the top has me puzzled. What would need to know that the clutch is at the top of its travel? Any help here would be good but I may need to make another trip to dealer to see what they know. Thanks again. |
Yes bottom clutch switch for NSS. I didn't use the upper switch for anything. I imagine it is there to disengage cruise control just like the brake switch does. The following thread contains a few of my pictures for connecting clutch switch and reverse switch on trans to operate back-up lights:
http://www.subaru-svx.net/forum/show...reverse+switch
My Write up has a pic of what I did to mount the rear of the shifter on my first 5-speed...
http://www.subaru-svx.net/forum/showthread.php?t=54258
Huck Subaru Ambassador 92 SVX LS-Tour Magnaflow Exhaust, 5-Spd-AWD ![]() 88 XT6 AWD 5-Speed "Bride of FrankenWedge" 15 Impreza Premium Sedan 15 Crosstrek XV 5-Speed My 5-Speed "How-To" Write-up 1976 Pontiac Firebird Formula Current Count of Subaru's Owned.... "70" |
Thanks Huck. I've printed out your writeup and just about have it memorized. Until a few days ago I had not really gotten down to laying all the parts out and walking through what I need to do.
A question I have is how much travel the does the rear shift linkage have? When in neutral how much travel do I need to allow for in placing the rear bracket? Thanks |
The rear bracket won't have any travel, it just holds the shifter stabilizing rod stationary
Thanks Huck. I thought that might be the case.
One last one and I'll let you go. Your instructions says to modify SVX brake booster or install WRX booster. I'm guessing the SVX booster rod is too long? Anyway to modify the WRX pedals to accommodate to SVX booster? Sounds like getting the booster out is a real PITA. |
I haven't done the hydraulic clutch pedal set-up, but to use the Cable style set up, if you modify the SVX pedals and add the clutch pedal to the SVX pedal set, you don't have to modify the booster at all..
Swapping the booster is simple, it comes right out once it is unbolted from the inside. You just need to unbolt the master cylinder from it and pull it a tiny bit forward. After that the booster can come up and out.
I did my swap with hydraulic clutch. Didn't have to swap brake booster.
