what is your Ultimate SVX transmission package
Anyone who has experienced both the stock SVX trans and something different in an SVX:
Post up what your ultimate transmission package would be and why. I'll be swapping a new package into my 96 svx. I cant decide if i want to go manual or 4.44 auto. So i'm hoping others might shed some light with their personal experience. (also what gear ratios and diff ratios do you prefer for 5 speed) I have driven Stock, and 2 different 5 speed Svx's. I really hope to run 6 or 8lbs of boost in the future, nothing radical just a little extra go power. My tranny upgrade budget is $1500 for parts. My labor is free. thank you Steve |
Re: what is your Ultimate SVX transmission package
I have a 4.44 auto which is nice compared to the stock, and gets even better with the subiechips tcu and a quick change kit, but overall I like the WRX 5 speed swaps best, that is what I would go with if doing it again. I didn't like the 6 speed I drove as much, but that may because I am not used to 6 speeds and heavy clutch.
I love my 6-speed but I can see how it wouldn't be for everyone. With the short shifter and upgraded bushings it's extremely raw and the responsiveness of the car changes completely. It becomes very snappy and can be a bit jumpy at low speeds. The clutch is heavier than most but has excellent feel. My Legacy also has a 6-speed so the two cars feel remarkably similar.
The 6-speed is also expensive as f***. The swap cost more than the car.
I agree with crazy, I love my 6 speed with short throw, but then again I am not your average driver. I think for simplicity 4.44 auto would be good way to go, especially with a 96 because of the check engine light as mentioned. but WRX 5 speeds also are good. I have not driven any manual svx except mine but I have driven a few wrx's
I have the WRX 5 speed in my '97. I wanted the best I could get, the meanest, toughest, baddest shifting car the SVX could be. Then I found out that you don't necessarily get higher gearing, you get more responsiveness throughout the same range by having the extra gear. Considering the limitations of the stock engine, I figured the 5-speed would be more than enough and it is soooo much more fun than the auto was. It seemed to me that the 6-speed was meant more for a boosted, hard-core SVX. Just my opinion on what I wanted. The 5 speed is a blast, transforms the car, without putting it in the hyper aggressive range. It feels right for my car. Unfortunately, the 5 speed definitely leaves me wanting more power. I can't imagine what the 6 speed would do to me. Sorry, don't know my gearing.
And, the CEL is on, though we took a stab at a solution. Eventually, I'll pull the bulb. |
New York registration + 1996 = automatic, period.
There is not a default rearward bias in the STI 6-speed center differential. It is a computer controlled clutch pack. The numbers you are quoting are the maximum F/R bias the differential will provide when the bias is dialed towards the rear.
Thank you all for your input!!!!!!
I spoke with the Inspector guy at my local shop yesterday. he is leaning toward it not passing... HOWEVER, he did say that the NYS inspection computer does allow 2 or 3 registers to be "Unready" And thinks there may be a chance that the NYS computer will know the difference between the MIL being set because of Emissions or because of Other issues. AND it may allow the Other issue. He doesn't know for sure. SO I have a question, Instead of carrying thru with the swap and crossing my fingers, can i do this? Drive the car there with all the original tranny. When i get there, unplug the trans control computer. and hook up to the NYS Inspection computer. Would that basically be the same "Inspection computer-wise" as putting a manual tranny in the car? this way we will really know if the NYS computer will allow it without the work and expense of really doing the swap.. thoughts? |
if you do not have a DCCD controller it will "default" to 36F/64R for 04 and 05 and I believe 41F/59R for 06-07
I like a JDM SVX transmission that I've gone through matched up with one of my TCUs. I like the 3.7 gear ratio. I like the way the car drives with the vtd. I like the way the car launches with the vtd. I like the fast shifts and I like that it doesn't break.
I had an SVX that i put a JDM SVX tranny with the 3.70 in a long time ago, It was a pain to get a TCM at that time. and when i did spend 250 for it, i really dont think it was right.
But i would try it again. Although, this being a 96' does it have to be a special TCM? |
You'd have to check what TCU you have now. Some of the earlier 96 SVXs have a TCU that is physically the same as the earlier SVXs. If I remember correctly the code on them is MQ. That TCU will work fine. If yours is later and has the little tcu with no provisions for external memory like the 97 cars then you are out of luck.
You can experiment with this - disconnect the trans from the engine ECU, get MIL lit, hook up for inspection. If it passes, you can do whatever transmission thing you choose, albeit with a perpetually lit MIL. If not, you're stuck with stock. A better alternative if you want a different driveline? Sell your SVX and buy an OBD-I car. Modding an OBD-II car in NY means reversing it every year, and you'd have to be pretty hardcore to swap your transmission every year when there's a much simpler alternative.
