Old 09-29-2015, 12:27 PM
neverLift neverLift is offline
Wanted: Crank/Cam Position Sensors
Looking for known working/good condition crank position sensor #1 (vertical plug).
Let me know if you have any.
cheers
Old 09-29-2015, 12:46 PM
Re: Wanted: Crank/Cam Position Sensors
You can use the Crank and cam sensors from a EJ motor, the mounting tab is different, but can be modded to work, the sensor is the same thing, I have done this, it will work
Old 09-29-2015, 01:03 PM
Thanks, I may resort to a EJ22 sensor, but if I can I'd like to not have to modify anything.
cheers
Old 09-29-2015, 01:23 PM
cheers
New EJ22 ones are about $20 on Rockauto.com (for a 1998 Impreza 2.2).....a bit cheaper than the SVX one.....
Old 09-29-2015, 01:34 PM
Yeah! Crazy the difference for a slightly different shape of plastic.
I take it I'd need a matching plug for the Legacy sensor, and then file/slot the bolt hole to line up with the SVX CPS bolt hole?
cheers
Old 09-29-2015, 01:44 PM
Nope, the SVX wiring plugs right into it, then just turn the sensor until the SVX bolt will catch the side of the sensor (the hole is a slightly different distance out).
The sensor has no pressure on it, so the bolt is just to hold it in.
Old 09-30-2015, 09:23 PM
Thanks for that! I picked up a CPS from a 2003 Impreza Outback (was the only Subaru at the junkyard) and it worked. Had the correct plug and oriented it as you described. I appreciate the help. Here are some photos for anyone searching this in the future.
If anyone has a working #1 crank sensor (vertical plug), I'm still interested.
cheers
Old 10-01-2015, 05:23 AM
Glad I could be of assistance! And glad you're SVX is back on the road!
Old 10-01-2015, 05:59 AM
I've got a #1 sensor on my parts car. I'll remove it this morning and send you a PM when I'm sure I didn't damage it.
It's 0.2 degrees C out there.
Old 10-01-2015, 09:54 AM
Awesome! I appreciate it, working in the cold is no fun.
Cheers
Old 10-01-2015, 11:19 AM
On mine there's a vertical plug Jecs A29-000R1? and Jecs A29-000R00 with an angled plug. Which is it?
Old 10-01-2015, 02:30 PM
The vertical plug A29-000R1, should be the one slightly closer to the PS pump.
Cheers
Old 10-01-2015, 03:57 PM
I sent you a PM.
Old 02-03-2016, 02:04 PM
Still looking.
cheers
Old 03-01-2016, 03:46 PM
bump!
_____
