Thread Tools | Rate Thread | Display Modes |
Starter, power steering pump, ac compressor, engine parts, etc
I have the following sitting on my shelves that I would like to sell.
SOLD: two complete power steering pumps with pulley and mounting assemblies SOLD: .25 undersize coated aluminum rod bearings SOLD: .50 undersize coated main bearings SOLD: starter SOLD:two ac compressors Stock SVX intake camshafts std size aluminum rod bearings 3.545 ring and pinion
Michael Emery, MBA, MS 94 SVX LSI, Ebony Pearl profile 94 SVX LSI, Ebony Pearl from back Performance and Multi-Fuel Tuning Last edited by longassname; 09-20-2015 at 06:26 PM. |
Re: Starter, power steering pump, ac compressor, engine parts, etc
Is your PS pump rebuilt?
1994 SVX LSi JDM Tailbar and Grill, Clear Corners, 15min-mod, Nevin Blue RSB, G-FORCE SPORT COMP-2 Tires, Phenolic Spacers (Manifold & Throttle Body), SS Brake Lines, Maniac Electric Motors 160A Alternator 2008 Legacy 3.0R |
Both power steering pumps came on low miles JDM engines.
How much shipped for one of the power steering pumps. 29687.
I just shipped one to Matt and it had a yellow cap. The other one I have has a black cap. I'm thinking it's probably off a US engine. It would still be a low miles engine though. These came off of engines I purchased as cores to rebuild. I've never messed with crappy cores. All the US engines I've rebuilt have been low miles 96 or 97 engines that spent most of their lives on a shelf indoors at a large auto salvage yard.
Flystyle if you need one I'm not trying to get an arm and a leg for this stuff. |
power steering pumps are sold.
It looks great! Thanks for the part. I know it will come in handy.
I was moving stuff around to pull out the starter and the ac compressor and found that I have one more power steering pump. This one has a yellow cap so it's probably off a JDM engine.
Thanks, hopefully you won't need it too soon.
What condition is the AC compressor in? Mine has been making a tapping noise upon first starting up for a few years now. I assume it us the clutch and will fail soon. But who knows, the damn thing has already surprised me for three years.
It looks very nice. I should probably take some pictures and post. As a general rule any part I kept a hold of is much nicer than what people here are used to. It would be another JDM engine take off.
^ I recieved mine two days ago. Thanks for the quick shipping.
The reservoir tank is bent at one of the lips but I can swap over mine.
How much? And what would the shipping be to 14845?
I took pictures of the power steering pump, the ac compressor, and the starter.
I recognize the starter. It is off of the 8.5 compression engine that was in my Ebony. It is not an SVX starter. It does fit in and work well in an SVX. I purchased it from a salvage yard off of some other model of Subaru that was only a few months old at the time. It was on my ebony for probably 2 years. I see black paint on the power steering pump. That means it was re-manufactured. The ac compressor is probably off of the JDM engine that is in my ebony now. I had an a compressor I purchased new from the dealer on my ebony and swapped it onto the JDM engine when I installed it. |
