Old 03-12-2015, 08:33 PM
solodon solodon is offline
Engine miss and 99 outback
Hi, recently my 94 SVX has developed an infrequent miss while sitting at a light. Like one cylinder didn't fire then runs fine for 5-10 seconds and will maybe do it again. Not every light just once in a while.
Friend totaled a 99 Legacy outback automatic AWD. I'm thinking the 4.44 is the gears in this but all references I've seen only go up to using 98 trans and diff. What's different or can the 99 be used?
Thanks, Don
Old 03-13-2015, 05:20 AM
Re: Engine miss and 99 outback
If it is a '99 with the SOHC engine it won't work. They changed over to the new engine and tranny in '99 and it's not easily compatible.
Old 03-13-2015, 05:37 AM
theflystyle's Avatar
Could be the coils? I had similar issues and when I replaced mine (with better condition used ones) the problem disappeared.
1994 SVX LSi
2008 Legacy 3.0R
Old 03-13-2015, 11:48 AM
The outback is a turbo and I'm not sure but that might be a 2.5.
Old 03-13-2015, 02:39 PM
Old 03-13-2015, 06:00 PM
I'm sure I could find some used ones and if that took care of the problem that would be only OK as I'd have 6 coils and not know which one(s) are bad. I hate to fix what isn't broke.
Old 03-13-2015, 06:50 PM
Check the resistant for each one. If you have the manuals its in the "Engine electrical system" one on page 17. It states:
measure the primary coil resistance. If the resistance is extremely low, this indicates the presence of a short-circuit
Specified resistance:
[Primary side] 0.68 - 0.83 Ohm
So check your coils and see which one could be bad. Its a free somewhat easy check. I would grab the manual as it explains how exactly to check the coil.
1994 SVX LSi
2008 Legacy 3.0R
Old 03-13-2015, 09:58 PM
Thanks flystyle, after I'd posted I looked in the manual and found that information. I keep forgetting I have the manual. Also sometimes there are other ways to check things that people have learned that aren't in the book and easier. I'll start there but concerned that since it is so infrequent it might not show up with the ohmmeter.
Don
Old 03-14-2015, 06:08 AM
I had a misfire which only showed up when the engine was hot and under load such as climbing a hill. It was one bad coil.
If you unplug one at a time you can easily find the bad one. If you unplug a good one the car will run worse. If you unplug a bad one the car will run the same.
Old 03-14-2015, 10:21 AM
Thanks Blacky. The miss is VERY infrequent so getting to duplicate the conditions is difficult. Seems I'd have to drive with a coil disconnected, running on 5 cylinders and see if while sitting at a light I get a miss. After a few days change which is disconnected and drive like that again until I never get a miss. When I had a coil go bad I disconnected an injector to find the bad coil. Seems it would be easier on the car to drive with an injector disconnected as I'd not be putting fuel into a cylinder that may not fire infrequently. Testing the coils electrically as described in the manual seems the way to go at this time.
