Old 03-01-2015, 06:36 PM
blue thunder blue thunder is offline
Intake manifold removal estimate
I have a leaking coolant line or lines. I can squeeze the outgoing hose from the radiator and see coolant coming out of the back of the engine area. I don't think this is fixable without removing the intake manifold. I don't have the experience to do this myself. Can anybody give me a ballpark figure on the labor charge to remove the manifold and replace the coolant hoses. I would think they all need replacing after twenty years. Any ideas on this appreciated.
Mike
95 Pearl Blue L
Old 03-01-2015, 07:34 PM
Re: Intake manifold removal estimate
Mike
I just had the same issue. Mine was a bit of a emergency service since I was a few hours from home when the coolant hose burst.
The bill came to almost $400 but I'm guessing that my trusted local shop would have done it for about $100 less. It was about 2 hours labor to take off and reassemble the manifold, plus the cost of the hose, plus they charged me for a coolant flush.
They were able to reuse my gaskets, mine were only a year old and new ones would have take a few days to come in since there were none local. Yours will probably need to be replaced.
Old 03-01-2015, 08:25 PM
Thanks for the reply. I'm not taking it to a dealer. I am lucky enough to have a reputed auto repair shop inside of a mile from where I live. My car won't have time to overheat. I think I will take it there tomorrow and have them look at it.
Mike
95 Pearl Blue L
Old 03-01-2015, 08:27 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Send a message via AIM to Stevebsy Send a message via Yahoo to Stevebsy
Which side at the rear is leaking? There is one short hose fairly far underneath the IM, which would be difficult to impossible to replace without pulling the manifold off. The heater hoses can be done without removing the IM. You have to pull the airbox stuff off, then it is not so bad. There are also hoses going to the throttle body.
Should be a diagram around here somewhere...
'93 Anniversary Edition SVX 122k - 3.7 FD 5MT Swap, ECUtune 1a1, Bontrager RSB, Mad Restoration underway!
'20 Honda Ridgeline
Custom Oil Caps, Battery Bars, Phenolic Spacers for sale here:
http://www.x35design.com
Old 03-02-2015, 07:41 AM
wdb wdb is offline
dances with roads
If you're taking the manifold off, and it hasn't ever been off, you might want to consider doing a few other things while you're there. PCV valve, knock sensors, replacing all of the vacuum lines. Others here with more experience may have other suggestions.
1995 Caterham 7 Twincam
2007 BMW 328i Cabriolet
2012 Tacoma 4wd v6 Access Cab
Old 03-02-2015, 11:11 AM
All the vacuum hoses will be very brittle and most likely several will break when they have the manifold off. While they are in there is the time to do it.
Old 03-02-2015, 12:26 PM
EdWindows's Avatar
EdWindows EdWindows is offline
5spd + coilovers = win :D
Make sure to have a Dremel handy for cutting some of the vacuum hoses off the sensors, as they may be so brittle that you'll break the nipples off the sensor while trying to remove the old hose.
1992 Dark Teal LS-L w/ 165k+ miles (traded )
Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs
2001 Black Toyota Sequoia (hauler/daily)
1992 Blue Toyota Cressida (drift car)
1992 Red Toyota MR2 (weekend/track day car)
Old 03-02-2015, 05:30 PM
michael's Avatar
michael michael is offline
What Potholes ???
If it's just the lines going to the throttle body they are fairly easy to change without removing the intake. Can you snap a pic of where the leak is coming from?
Wanted: Steering Wheel
