#2536
Another 500km trip, Hamilton to New Plymouth. Got to love Mount Messenger.
Finally fitted my BBS wheels and replacement tyres. Drives much nicer, the old tyres were well past their useful life span. Paid someone smarter than me to fit a new alarm with remote start. Seems to be very rare to see remote start cars in New Zealand. Don't know why, certainly couldn't buy a reputable brand alarm / starter kit locally from a dealer. Ended up importing an Avital made by Directed Electronics (aka Clifford, Viper et al) Still have to put my dash back to together. It's been dangling around my knees for the past 6 months now. |
#2537
I changed the oil to for the Forester and spark plugs for the Outback, which was actually easier than with the Forester. A little bit more space available even with the EZ30R.
The SVX is off the road for the winter, so it's stored on the lift..... had to reverse it out for the work above. Really hard to get it back inside the garage on summer tires - we just got 8" of snow . /T Last edited by Tapani; 12-26-2014 at 08:24 AM. |
#2538
So what kind of bikes are hiding under those covers?
#2539
A 1986 VFR, a 2008 Varadero, a 2011 Duke and a 2013 NCX with the dual clutch tranny. An automatic bike is a cool ride :-).
/T |
#2540
Yes they are, but when the battery dies or gets low. You can't push start it.been there done that.
#2541
Replaced the rear speaker with a couple of nice kicker units. Speakers were too tall to fit under the package tray without trimming, so I just installed them from the bottom. Worked perfectly and no modification to the factory equipment.
Also if anyone knows where I could pick up a couple of good speaker grills for the rear package tray,that would be awesome.
1992 Subaru SVX LS-L Pearlie 1989 Mazda RX7 2005 Mini Cooper S |
#2542
Broke out the way back machine and fixed my ac, defrost wasn't working well. Evacuated the system, replaced leaking valves, vacuumed it out, filled it up with 28oz of r12. Works great.
Current Stable: 1992 SVX 1979 K5 Blazer Cheyenne 1956 Plymouth Belvedere - Daisy 1967 Chevy C20 1953 Chevy 210 1969 Plymouth Satellite 1949 Chevy Thriftmaster 1959 Chevy Apache 1951 Chevy Stepside 1969 Chevy Camper Special 1978 Ford F150 w/ stroked 460 1986 Volvo 740 turbo wagon 1999 GMC 2500 Creep Van 1994 Impreza Outback |
#2543
Can I borrow your way back machine?
#2544
That's what I call my old r12 evacuation/recharge machine. Calling it this gets me out of long explanations about the history of refrigerants and the environment when someone asks what it does.
#2545
Maybe have a heart felt talk with someone, and maybe rip out someones adams apple, crush their head and feed them to the pigs.
#2546
As soon as I can get that machine you will be the first to know.
#2547
Thank you, Good Sir!
#2548
Recent updates:
- Group N motor mounts - "New" TPS - New coolant temp sensor - Re-shimmed 3.90 rear diff - New exhaust gaskets - Poly rear diff bushing inserts Coming soon: - 1 piece driveshaft - Replace front passenger ABS sensor - Pray to God that the mapVSS wheel speed interpreter works with the SVX abs system. Also need to figure out why my cooling fans are running all the time (with AC on or off). They run with the new or the old CTS installed. Connection seems good. Gonna start poking things with a multimeter to check voltages. Unless there's some relay or module that is telling them to run all the time.
Mark S. 1995 LSi, EPM, #1152, 197k(ish) miles, 5-speed |
#2549
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
#2550
