Old 09-22-2014, 06:38 AM
theflystyle's Avatar
Originally Posted by Coan View Post
Got a code P0330 (knock sensor malfunction, bank 2) on my way home today. Drove across the metro to the only AutoZone that had one in stock. Replaced the driver's side knock sensor and the leaking oil pressure sensor in about an hour. Wasn't too bad a job.
Very coincidental....
I got up Saturday with the intention of getting my emissions inspected. When I started the car I of course got a check engine light (first time in years) and it was the for knock sensor (passenger side). I ordered a pair of replacements from Rock Auto since I didn't particularly like the brands Advance was selling. Now on to finding instructions on how to change them. I have done it on the 94 Legacy many times before but those were easier to get to apparently.
1994 SVX LSi
2008 Legacy 3.0R
Old 09-22-2014, 10:32 AM
92 SVX 92 SVX is offline
Take off the alternator and using a ratcheting wrench (if you have one) carefully pull the bolt out. If no ratcheting wrench normal will do just takes longer/harder to do. The Passenger side is easier to get, its farther forward on the engine, the drivers side one is farther back, may have to get that by removing the throttle body and reaching in from the back.
Old 09-22-2014, 04:28 PM
SVX8588's Avatar
SVX8588 SVX8588 is offline
Crushed the little ferrite thingy in my ECU today. Then seafoamed it through the larger hose on top of the intake. No hesitation and smoother idle now. Plus it seems to have solved my high idle problem.
Now I might actually drive it a little again before I sell it
Glen
SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery
2002 F550 74K
SOLD - 2000 F450 215K
1987 BMW 535i 209K
1999 Yamaha SRX 700
Old 09-22-2014, 09:59 PM
Coan's Avatar
Coan Coan is offline
Alleged User
Funny you mention not liking the brands at Advance. I should have just ordered mine from RockAuto as well, but Autozone had them in stock so I just went with it. The Duralast oil pressure sensor that I put in is faulty and it makes me a little nervous about the Duralast knock sensor I installed. I also replaced the Duralast coolant temp sensor that I installed a year ago that I think was bad from the start. I'm done with all Duralast parts at this point.
As for replacement, follow what 92 SVX said. Remove the alternator and you'll have access from the front side. I was able to get the driver's side sensor by doing that, which is farther back and harder to get to, but I have small, skinny hands so I tend to have less issues reaching things in tight spaces than most people.
Jon
1997 SVX LSi Bordeaux Pearl
1995 SVX L AWD Polo Green - 277k miles
1986 Pontiac Fiero 3.4L Twin Dual Cam V6
Old 09-23-2014, 01:38 PM
Thanks for the how-to. Sounds like the driver side is going to suck
I try to keep the times when I use off the shelf brands to a minimum and like most its about $$. OEM is just crazy expensive for knock sensors but the lifetime warrenty for most of these aftermarket ones make it a little more reassuring if need be. I actually had replaced two Bosch knocks on my Legacy that never seemed to work well with an Advance brand (forgot) which has kept the CEL out for sometime now.
1994 SVX LSi
2008 Legacy 3.0R
Old 09-23-2014, 03:34 PM
In my experience and that of some other Members, Subaru is the only place to go for oil pressure sensors, two wire water temperature sensors and GASKETS AND SEALS!
Sorry for the rant.
We also have to go to Subaru for ball joints.
I have never had a problem with an aftermarket water pump, although YT does not use them due to his bad experiance with them, Mike, aka Longassname also does not use them.
I go with Subaru thermostats and hoses.
I USED to only go with Subaru radiator caps but the quality of the caps seems to have declined.
For axles you have to measure the hub to make sure that it was made correctly or you end up with an inner axle seal misfit. (Outer SVX Axle hub diameter 59 MM is correct).
But Miller brothers, Advance Auto Parts and Auto Zone seem to be fine, as long as you measure them.
I hope that this helps.
Old 09-27-2014, 09:06 PM
So I changed both the knock sensors after getting a code for just the bad passenger side. It was my first time and it took about 2.5hrs. I removed the alternator and it made it much easier but I still had to ask my wife to get to the drivers side after I loosened the bolt
Oh. Yeah, I thought I would show you what BOTH of the old knock senors looked like. (Can anyone tell if those are the original ones by any chance)
I have never seen or heard of that happening before. Any ideas????
1994 SVX LSi
2008 Legacy 3.0R
Old 09-28-2014, 12:18 AM
MELTED!?!?
The top of your block should never get over about 210°f!
Old 10-02-2014, 11:37 AM
Finally got the front brakes done. Seems like they have not been working for some time. We did rears 4 months ago ( suspected a frozen caliper, as the right rear got extremely hot) and then the fronts started chattering. Removed rotor and it was solid rust on the inside surface. See this image ::image.jpg. Wow they feel great now. Ceramic pads.
Wish I could post 2 photos.???? How?
Why did this happen
Old 10-03-2014, 01:34 PM
Put a my 6th set of tires. Pirelli P7 Cinturato All Season Plus tires on the 2010 Outback. After much research and reviews, these seem to be a really great tire in all areas. Read reviews on Tire Rack, 1010 Tires, etc.
The Michelin Premier AS scored a bit higher in some areas, but are a lot more expensive.
Look how poor the ContiProContacts were. These were the new-generation Outback's OEM tire. Rated 22. Had 5 sets of them on for the past 250,000 miles.
Old 10-05-2014, 02:50 PM
michael's Avatar
michael michael is offline
What Potholes ???
Big thanks to Denny "Pearlm30" for meeting me half way to pick these new BBS wheels up. Always nice to deal with him.
Wanted: Steering Wheel
Old 10-06-2014, 04:23 PM
Detailed my trunk. Vac it out, cleaned all the area around the trunk area. Waxed areas that can't be seen with trunk closed. ( all areas around the trunk support,and underside of lid. ) took it for a ride with new brake pads.. No vibration in the steering wheel. ( have always felt a slight tingle in the wheel. Found the reason for sure. ) stops are very smooth.
Old 10-06-2014, 05:34 PM
Enjoy it, I can't stand driving with warped rotors.
Old 10-06-2014, 06:08 PM
trueblue's Avatar
trueblue trueblue is offline
Send a message via AIM to trueblue
Posted pictures of the carshow last Saturday.
https://www.dropbox.com/sh/5bnkbos0t...LF08mtxba?dl=0
[SIGPIC][/SIGPIC]Kenyatta
The farther backward you can look, the farther forward you are likely to see. -Winston Churchill
My baby: 94 lsi
My fast baby: 2001 Suzuki Marauder
My new baby: 2010 Subaru Outback
Old 10-07-2014, 08:20 PM
AlcyoneSVX's Avatar
Alcyone Silver Contributor
The Pearlie turned 200K today!
ARMANDO
2004 Mazda RX-8
1974 Mazda RX-4
