Old 06-09-2014, 10:59 AM
GRN_NVY's Avatar
GRN_NVY GRN_NVY is offline
Hood struts: FYI
Hi all,
I followed a thread to discover the replacement hood struts needed for the LS I just acquired. I called the company to order and was told that it would be another month before they would have any. Anyone have ideas where I might get some? Both of the struts on my car are shot and worthless. I've called a couple of auto parts stores and no one seems to have a cross match (for the GSNI-2449-89).
~I hear and I forget, I see and I remember. I do and I understand~
1994 Subaru SVX LS_Color: "Infinity/Emerald Mist"
My Other Ride is a Sailboat: San Juan 7.7M
Formerly owned 3 Subie XT's
Old 06-09-2014, 11:19 AM
gwynethh's Avatar
gwynethh gwynethh is offline
Re: Hood struts: FYI
Have you tried McMaster Carr to see if they have an equivalent?
http://www.mcmaster.com/#
Old 06-09-2014, 05:29 PM
http://www.subaru-svx.net/forum/show...5&postcount=27
Old 06-10-2014, 08:31 AM
GRN_NVY's Avatar
Actually, this is my first knowledge of these folk. Great site though! I plan to spend some time checking them out for other stuff too.
Thnx!
Old 06-10-2014, 08:37 AM
GRN_NVY's Avatar
Great info, saving for future reference ...
Thnx
Old 06-10-2014, 03:44 PM
theflystyle's Avatar
Thnx
Ditto - Another great forum resource!
1994 SVX LSi
2008 Legacy 3.0R
Old 06-11-2014, 04:57 AM
Grn Nvy I just got thru doing this on the Pace Car, a local shop got the struts for me (cross-over from the part number in the Link John added a couple post up) a LOT stiffer than a set of new stock ones, should hold the SVX hood up for many years
Old 06-22-2014, 05:30 AM
GRN_NVY's Avatar
Got my springs this week, installing today! Thanks all for the interest and the help.
Old 06-22-2014, 05:38 AM
GRN_NVY's Avatar
Thanks! Got my pair from McMaster's for just over $37.00 shipped.
Old 08-05-2014, 10:32 AM
Pav625's Avatar
Pav625 Pav625 is offline
... a work in progress
Any chance you have the part number for these? Been looking over the site, but not feeling warm & fuzzy about what I'm looking at! Also, have you had a chance to install them yet? If so, how do you like them?
1992 Pearl LS-L : Trans-cooler / ecuTUNE Stage 1 Chip / Pioneer AVIC-U310BT Navigation
I hear what you're sayin', but whatta ya mean?!
Old 08-05-2014, 03:19 PM
Ron Mummert Ron Mummert is offline
Invisible avatar
Send a message via AIM to Ron Mummert Send a message via Yahoo to Ron Mummert
Lightbulb Re: Hood struts: FYI
Or.....you can do the 5 cent solution. Find a 2' or longer piece of 5/8th PVC pipe. Find a bench saw. Put saw fence close to the blade, lower blade enough to just cut through one side of the pipe, & run the pipe 2, or 3 horizontal passes through the blade. Cut the slot at least 6" long, or whatever needed to slip over the strut piston when hood's up. Cut the pipe to length from the leftover piece that kept your fingers from bleeding profusely. Raise hood, & snap piece on piston. This fix will outlast a middle east war. The pipe's groove will slip on & store on the battery hold-down piece. You're welcome.
Ron.
Good s**t happened. 69 was worth the wait.
'92 stock semi-pristine ebony - 160K
'96 Grand Caravan - 240K
'01 Miata SE - 79K
'07 Chrysler Pacifica - 60k - future money pit.
Old 08-05-2014, 06:55 PM
Let's see a picture of that PLEASE. . A few different views. I use a very small vice grip.
Old 08-05-2014, 09:47 PM
GRN_NVY's Avatar
Hey,
Sorry, haven't been on in a while, just saw your post, but in bed already. I do have the part number & YES! They're installed and I LUV-EM! I ordered the wrong ends though (the threaded ones) still, no major mods - less than 2 bucks in "stainless" nuts & washers, they were in (both sides) in less than 10 monutes. A bit of warning though... after install, work out at the gym for a while to prepare for opening the hood for the first time ... think "catapult or slingshot"... on the other hand, forget the gym, you'll work your Biceps & Lats just closing the hood ;-) ... Just kidding! Don't have the paperwork handy now, but will dig out and send to you tomorrow. Ah-ight?
Old 08-06-2014, 10:16 AM
Pav625's Avatar
Hey,
Nice, it'll be nice to finally ditch the redneck vice grip setup I'm currently using!
Old 08-06-2014, 10:35 AM
Invisible avatar
Smile Re: Hood struts: FYI
If I knew how to do pics, I'd be less wordy. One more time....
Close your eyes & imagine a SEVEN inch ( I measured this time) long piece of 5/8" PVC. Imagine a 1/4 wide groove cut along the length of it. Looking at the end of the piece you'll see the letter "C". So, to get that cut, you need to run the pipe along a bench saw blade that's raised no more than 1/4". Run pipe through once. Then turn slightly & run again, probably 3 times, in order to get a 1/4" wide slot. It will now snap on the raised hood piston. Phew!
'01 Miata SE - 79K
