Go Back   The Subaru SVX World Network > Regional SVX Forum & Clubs > Down Under
Old 05-26-2014, 01:27 AM
andreoz andreoz is offline
Send a message via Skype™ to andreoz
Dashboard & Heater hoses
Has anyone had the experience of the inside of the car being flooded with steam and coolant from under the dashboard? Not an experience I would like to repeat. Diagnosis was either the heater hose broken or heater core gone. Decided on the quick fix to isolate the heater as mechanic told me that taking the dash out and locating the fault is going to be very expensive. How difficult is it to get the dashboard out and get at the heater hoses and core?
Old 05-26-2014, 02:37 AM
ShaneHobson ShaneHobson is offline
Re: Dashboard & Heater hoses
This site lists the steps (scroll past the other Subaru models to get to SVX).
Probably not good enough to follow without some photos, but it will give you a quick idea as to how difficult it might be.
http://www.autozone.com/autozone/rep...96b43f8037a879
The factory service manual would be a good place to start.
http://www.subaru-svx.net/forum/showthread.php?t=55141
Old 05-27-2014, 06:05 PM
'E''s Avatar
'E' 'E' is offline
It's happened to me I have a workshop manual if you need info on remove dash etc
92 pearl SVX about to revive
92 Black 4ws (Jap spec) SVX
93 black SVX
93 Liquid Silver SVX - sti 6 speed with R180 diff, my05 sti steering wheel, sti alloy lateral links, 19x8.5 275/30 42mm offset front and 19x8.5 275/30 22mm offset on the rear, 6 pot brembo caliper with 355 rotors front, 2 pot brembos rear
95 bright red SVX
96 emerald pearl SVX about to revive
Old 05-27-2014, 06:53 PM
Sean486 Sean486 is online now
Here is the procedure
File Type: pdf MSA5TCD95S_27_instrument_Pannel-DASH REMOVAL.pdf (352.8 KB, 135 views)
Old 06-01-2014, 04:04 AM
93tzlegacy 93tzlegacy is offline
heater core for sure.
Old 06-02-2014, 02:46 AM
Well after isolating the heater core and deciding to be without a heater, on the way home the Antilock Barke light was on but brakes were all OK. Not for long - some 15 minutes into the trip my brakes failed completely - pedal rock hard and no brakes!!!
It appears that the coolant when leaked out under the dashboard, was not cleaned up properly and drowned the Brake control unit!!!!
Not having much luck with my SVX lately!!!
Old 06-02-2014, 01:28 PM
Note to self : if I ever build or design a car from scratch, don't put sensitive electronics on the floor !
